はじめに
Follow this guide if you need to replace the push button interface of your Aroma ARC-914SBD rice cooker. This guide must be accomplished in order to access the push buttons and LED lights for replacement.
必要な工具と部品
Locate the piece on the black plastic trim that is opposite from where the hinges were. Carefully, pry the bottom edge of this piece outward (away from the stainless steel side) about 1/4 inch to pull the tab out of it's hole. Once the bottom is pried out a bit, the tab can be seen from the bottom. Press up on the tab with a screwdriver.
Next, you must remove the upper black trim which is connected to the inside liner with tabs. To do this you must hold the interior walls still, while rotating the trim so that the tabs line up with the slots. (tabs cannot be seen at this point, pics are to give you an idea of what you cannot see inside the device)
ある他の人がこのガイドを完成しました。
