メインコンテンツにスキップ
はじめに
This is the first step taken in order to fix many of the parts in this device. Be careful to not strip any of the screws.
パーツ
パーツは指定されていません。
  1. Begin by removing the condensation catcher to expose the screw. Pinch the condensation catcher from both sides and pull. Begin by removing the condensation catcher to expose the screw. Pinch the condensation catcher from both sides and pull.
    • Begin by removing the condensation catcher to expose the screw. Pinch the condensation catcher from both sides and pull.
  2. Remove the screw that was behind the condensation catcher using a Phillips head screwdriver, size PH2.
    • Remove the screw that was behind the condensation catcher using a Phillips head screwdriver, size PH2.
  3. Remove the piece that was held by the screw by pulling out from the top, then pulling up. This will expose the hinges for the lid. Remove the piece that was held by the screw by pulling out from the top, then pulling up. This will expose the hinges for the lid.
    • Remove the piece that was held by the screw by pulling out from the top, then pulling up. This will expose the hinges for the lid.
  4. To remove the hinges, rotate the bottom of the rod upwards, then push inwards to pull them out. Repeat the process for both sides. This will allow the lid to be removed. To remove the hinges, rotate the bottom of the rod upwards, then push inwards to pull them out. Repeat the process for both sides. This will allow the lid to be removed. To remove the hinges, rotate the bottom of the rod upwards, then push inwards to pull them out. Repeat the process for both sides. This will allow the lid to be removed.
    • To remove the hinges, rotate the bottom of the rod upwards, then push inwards to pull them out. Repeat the process for both sides. This will allow the lid to be removed.
終わりに
ある他の人がこのガイドを完成しました。
Brandon Nieves
メンバー登録日: 2015年09月04日
956 ポイント
8のガイドは作成済み
チーム
USF Tampa, Team 2-3, Sullivan Fall 2015 USF Tampa, Team 2-3, Sullivan Fall 2015人のメンバー
USFT-SULLIVAN-F15S2G3
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 824
