メインコンテンツにスキップ
APS Tech 101629 SCSI Connections Replacement
必要な工具と部品
  1. APS Tech 101629 SCSI Connections Replacement, External Casing: 手順 1、 3の画像 1 APS Tech 101629 SCSI Connections Replacement, External Casing: 手順 1、 3の画像 2 APS Tech 101629 SCSI Connections Replacement, External Casing: 手順 1、 3の画像 3
    • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
  2. APS Tech 101629 SCSI Connections Replacement: 手順 2、 2の画像 1 APS Tech 101629 SCSI Connections Replacement: 手順 2、 2の画像 2
    • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
  3. APS Tech 101629 SCSI Connections Replacement: 手順 3、 2の画像 1 APS Tech 101629 SCSI Connections Replacement: 手順 3、 2の画像 2
    • Flip the device right side up.
    • Gently slide the casing upwards and off the hard drive.
  4. APS Tech 101629 SCSI Connections Replacement: 手順 4、 1の画像 1
    • Flip device upside down again.
    • Gently pry the bottom gray casing away from the device.
  5. APS Tech 101629 SCSI Connections Replacement: 手順 5、 2の画像 1 APS Tech 101629 SCSI Connections Replacement: 手順 5、 2の画像 2
    • Rotate so the back of the device is facing you.
    • Gently pry the back casing away.
    • When the back casing is removed, the fan will become loose.
  6. APS Tech 101629 SCSI Connections Replacement, Internal Drive Component: 手順 6、 2の画像 1 APS Tech 101629 SCSI Connections Replacement, Internal Drive Component: 手順 6、 2の画像 2
    • Flip so device is upside down.
    • Remove 4 screws with Phillips #1 screw driver.
    • Be sure to save the washers that seperate the screws from the baseplate for reassembly.
  7. APS Tech 101629 SCSI Connections Replacement: 手順 7、 2の画像 1 APS Tech 101629 SCSI Connections Replacement: 手順 7、 2の画像 2
    • Slide the internal drive component away from the back of the device.
    • Remove the connections from the back of the internal component in the order of your choosing, we suggest left to right. The connections are:
    • Audio Connection
    • SCSI ID
    • Terminate On
    • SCSI Connection
    • DC Input (power)
  8. APS Tech 101629 SCSI Connections Replacement, SCSI Connections: 手順 8、 3の画像 1 APS Tech 101629 SCSI Connections Replacement, SCSI Connections: 手順 8、 3の画像 2 APS Tech 101629 SCSI Connections Replacement, SCSI Connections: 手順 8、 3の画像 3
    • Remove the four Phillips #1 Screws from back panel.
    • Once the screws are removed, the two connections are easily removed from the body.
終わりに
作成者
4人の作成者と共同で作成されました。
Patrick Meyer
メンバー登録日: 04/10/11
83 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 24-60, Amido Spring 2011 Cal Poly, Team 24-60, Amido Spring 2011人のメンバー
CPSU-AMIDO-S11S24G60
5 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 888
