この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This repair guide will walk you through the steps to removing and replacing the fan of your APS Tech 101629 CD-Drive. Fans are easily replaced and the process for removing this fan is fairly simple.
First the casing, channel switch, and power switch will need to be removed.
必要な工具と部品
Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
Find the conjoined ID cable wires that are colored black, orange, and yellow.
Lift white portion of cable wires to disconnect it.
Depress 2 pressure holds on each side of the power switch.
Press out the back of the device.
