はじめに
We will show you how to disassemble your tablet in order to access the battery. This replacement guide is helpful if you feel that your battery is faulty and no longer holding charge. Therefore, you need to replace it.
必要な工具と部品
To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
もう少しです!
終わりに
2 の人々がこのガイドを完成させました。
