メインコンテンツにスキップ
APEX AP-GS918 Battery Replacement
必要な工具と部品
  1. APEX AP-GS918 Battery Replacement, Power/Volume Button: 手順 1、 3の画像 1 APEX AP-GS918 Battery Replacement, Power/Volume Button: 手順 1、 3の画像 2 APEX AP-GS918 Battery Replacement, Power/Volume Button: 手順 1、 3の画像 3
    • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
  2. APEX AP-GS918 Battery Replacement: 手順 2、 3の画像 1 APEX AP-GS918 Battery Replacement: 手順 2、 3の画像 2 APEX AP-GS918 Battery Replacement: 手順 2、 3の画像 3
    • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
    • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
    • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
  3. APEX AP-GS918 Battery Replacement: 手順 3、 2の画像 1 APEX AP-GS918 Battery Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
  4. APEX AP-GS918 Battery Replacement, Battery: 手順 4、 2の画像 1 APEX AP-GS918 Battery Replacement, Battery: 手順 4、 2の画像 2
    • Begin removing the black tape covering the motherboard inside the tablet.
  5. APEX AP-GS918 Battery Replacement: 手順 5、 1の画像 1
    • You will need to desolder the two contact points that connect the battery to the mother board.
    • Make sure to allow ample time (at least 5-8 minutes or more) for the soldering iron to heat up. Otherwise, the solder won't melt.
    • Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
    • Make sure not to touch the contact points after desoldering them because they will remain very hot for a short while afterwards.
  6. APEX AP-GS918 Battery Replacement: 手順 6、 2の画像 1 APEX AP-GS918 Battery Replacement: 手順 6、 2の画像 2
    • Using the black nylon spudger, get underneath the battery and begin prying it loose from the rest of the tablet.
    • The tape holding the battery to the tablet has a very strong hold so be prepared for resistance.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Megan Lozicki
メンバー登録日: 02/19/15
416 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 9-1, Leahy Winter 2015 USF Tampa, Team 9-1, Leahy Winter 2015人のメンバー
USFT-LEAHY-W15S9G1
3 メンバー
9のガイドは作成済み
1件のガイドコメント
bien consejo, creo que es sencillo por todos para seguin estos pasos
harkhoscole - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 18
今までの合計 674
