メインコンテンツにスキップ
AEE Mach 1 Drone Propeller Replacement
  1. AEE Mach 1 Drone Propeller Replacement, Propeller: 手順 1、 1の画像 1
    • Make sure your drone is powered off and the battery is removed from the drone.
    • Identify the defective propeller on your drone.
    • Each propeller is marked as either 'A' or 'B'. Make sure the new propeller matches the old one.
  2. AEE Mach 1 Drone Propeller Replacement: 手順 2、 1の画像 1
    • In the center of each propeller, near the base, there are two arrows.
    • The symbol circled in red indicates the direction to "unlock" the propeller from the drone; this symbol indicates the direction to unscrew the rotor off of its mount.
    • The symbol circled in orange indicates the direction to "lock" the propeller onto the drone; this symbol indicates the direction to screw the rotor back onto the mount.
  3. AEE Mach 1 Drone Propeller Replacement: 手順 3、 1の画像 1
    • While keeping the motor under the propeller still, rotate the propeller in the direction shown to "unlock" the propeller.
    • The direction to unlock the propeller will depend on the letter labeled on the propeller.
  4. AEE Mach 1 Drone Propeller Replacement: 手順 4、 1の画像 1
    • Once you unscrew the propeller from the drone you will then be able to inspect the area for any additional damages.
  5. AEE Mach 1 Drone Propeller Replacement: 手順 5、 1の画像 1
    • Replace the defective propeller with one of the replacements that come with your drone, or you can attempt to fix the defective propeller.
    • To replace a propeller, simply place the rotor on the screw, and screw the propeller by rotating the propeller in the direction indicated by the arrow next to the “Lock” symbol.
    • The direction to lock the propeller on the drone will depend on the letter the propeller is labeled.
終わりに
作成者
5人の作成者と共同で作成されました。
Patrick Lewis
メンバー登録日: 09/04/19
382 ポイント
2のガイドは作成済み
チーム
University of Alabama, Team S1-G4, Bedsole Fall 2019 University of Alabama, Team S1-G4, Bedsole Fall 2019人のメンバー
UA-BEDSOLE-F19S1G4
4 メンバー
3のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 29
今までの合計 724
