メインコンテンツにスキップ
ACN Iris WG4K Video Screen Replacement
必要な工具と部品
  1. ACN Iris WG4K Video Screen Replacement, Handset: 手順 1、 2の画像 1 ACN Iris WG4K Video Screen Replacement, Handset: 手順 1、 2の画像 2
    • Press upwards with your index finger on the 4P4C connector as shown in the image.
    • Pull the connector gently out of its socket.
  2. ACN Iris WG4K Video Screen Replacement, Lower Case: 手順 2、 1の画像 1
    • Flip the main body of the video phone so that the bottom is facing up.
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
  3. ACN Iris WG4K Video Screen Replacement: 手順 3、 2の画像 1 ACN Iris WG4K Video Screen Replacement: 手順 3、 2の画像 2
    • Lift the back case upwards to expose the inside components.
    • Red rectangles indicate the three ribbon cables.
    • The orange square indicates the blade connector.
  4. ACN Iris WG4K Video Screen Replacement: 手順 4、 3の画像 1 ACN Iris WG4K Video Screen Replacement: 手順 4、 3の画像 2 ACN Iris WG4K Video Screen Replacement: 手順 4、 3の画像 3
    • Disconnect the three ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
    • Gently pull the ribbon cables out of their insulation-displacement connectors.
  5. ACN Iris WG4K Video Screen Replacement: 手順 5、 2の画像 1 ACN Iris WG4K Video Screen Replacement: 手順 5、 2の画像 2
    • Disconnect the blade connector from the blade receptacle by gripping the exposed area of the blade connector.
    • Gently pull the blade connector out of the blade receptacle.
  6. ACN Iris WG4K Video Screen Replacement: 手順 6、 1の画像 1
    • Gently lift up the lower case to separate it from the top case.
  7. ACN Iris WG4K Video Screen Replacement, Blade Connector: 手順 7、 1の画像 1
  8. ACN Iris WG4K Video Screen Replacement: 手順 8、 1の画像 1
    • Gently lift up on the upper case to separate it from the keypad/speaker panel.
  9. ACN Iris WG4K Video Screen Replacement: 手順 9、 1の画像 1
    • Use the Phillips #0 Screwdriver to remove the two Phillips head screws (5 mm) located on the upper case.
  10. ACN Iris WG4K Video Screen Replacement: 手順 10、 1の画像 1
    • Rotate the top case 180 degrees so that the video screen is closest to you.
    • Lift up the bottom up so that it is perpendicular to the table (this helps you reach the two top screws).
    • The four Phillips head screws (6 mm) are highlighted by the red circles.
  11. ACN Iris WG4K Video Screen Replacement: 手順 11、 1の画像 1
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm).
  12. ACN Iris WG4K Video Screen Replacement: 手順 12、 1の画像 1
    • Flip the top case so that the video screen is facing up.
  13. ACN Iris WG4K Video Screen Replacement: 手順 13、 1の画像 1
    • Rotate the top case 180 degrees.
    • Gently lift up on the video screen and the blade and ribbon connector to give you more slack to work with.
  14. ACN Iris WG4K Video Screen Replacement: 手順 14、 1の画像 1
    • Place the video screen face down to expose the two screws. The screws are indicated by the red circles.
  15. ACN Iris WG4K Video Screen Replacement: 手順 15、 2の画像 1 ACN Iris WG4K Video Screen Replacement: 手順 15、 2の画像 2
    • Use the Phillips #0 Screwdriver to remove the two Phillips head screws (6 mm)
  16. ACN Iris WG4K Video Screen Replacement: 手順 16、 2の画像 1 ACN Iris WG4K Video Screen Replacement: 手順 16、 2の画像 2
    • Pull the ribbon connector and blade connector through the top case.
  17. ACN Iris WG4K Video Screen Replacement, Video Screen Ribbon Cable: 手順 17、 1の画像 1
    • Note that the video screen is no longer attached to the top case, place in on a flat surface.
    • Gently lift of the silver casing.
  18. ACN Iris WG4K Video Screen Replacement: 手順 18、 3の画像 1 ACN Iris WG4K Video Screen Replacement: 手順 18、 3の画像 2 ACN Iris WG4K Video Screen Replacement: 手順 18、 3の画像 3
    • The two ribbon connectors are indicated by the red rectangles.
    • Disconnect the two ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
    • Gently pull out the ribbon cables. Gently pull out the ribbon cables.
  19. ACN Iris WG4K Video Screen Replacement, Video Screen: 手順 19、 1の画像 1
    • Gently lift the video screen out of its case.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Cason Fluharty
メンバー登録日: 02/14/17
107 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 20-4, Remmell Spring 2017 USF Tampa, Team 20-4, Remmell Spring 2017人のメンバー
USFT-REMMELL-S17S20G4
4 メンバー
20のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 9
今までの合計 234
