メインコンテンツにスキップ
ACN Iris WG4K Speakers Replacement
必要な工具と部品
  1. ACN Iris WG4K Speakers Replacement, Handset: 手順 1、 2の画像 1 ACN Iris WG4K Speakers Replacement, Handset: 手順 1、 2の画像 2
    • Press upwards with your index finger on the 4P4C connector as shown in the image.
    • Pull the connector gently out of its socket.
  2. ACN Iris WG4K Speakers Replacement, Lower Case: 手順 2、 1の画像 1
    • Flip the main body of the video phone so that the bottom is facing up.
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
  3. ACN Iris WG4K Speakers Replacement: 手順 3、 2の画像 1 ACN Iris WG4K Speakers Replacement: 手順 3、 2の画像 2
    • Lift the back case upwards to expose the inside components.
    • Red rectangles indicate the three ribbon cables.
    • The orange square indicates the blade connector.
  4. ACN Iris WG4K Speakers Replacement: 手順 4、 3の画像 1 ACN Iris WG4K Speakers Replacement: 手順 4、 3の画像 2 ACN Iris WG4K Speakers Replacement: 手順 4、 3の画像 3
    • Disconnect the three ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
    • Gently pull the ribbon cables out of their insulation-displacement connectors.
  5. ACN Iris WG4K Speakers Replacement: 手順 5、 2の画像 1 ACN Iris WG4K Speakers Replacement: 手順 5、 2の画像 2
    • Disconnect the blade connector from the blade receptacle by gripping the exposed area of the blade connector.
    • Gently pull the blade connector out of the blade receptacle.
  6. ACN Iris WG4K Speakers Replacement: 手順 6、 1の画像 1
    • Gently lift up the lower case to separate it from the top case.
  7. ACN Iris WG4K Speakers Replacement, Keypad Ribbon Cable: 手順 7、 1の画像 1
  8. ACN Iris WG4K Speakers Replacement: 手順 8、 2の画像 1 ACN Iris WG4K Speakers Replacement: 手順 8、 2の画像 2
    • Gently lift up on the upper case to separate it from the keypad/speaker panel.
    • The ribbon cable is highlighted by the red rectangle.
    • The 2-pin JST connectors are highlighted by the orange squares.
  9. ACN Iris WG4K Speakers Replacement: 手順 9、 3の画像 1 ACN Iris WG4K Speakers Replacement: 手順 9、 3の画像 2 ACN Iris WG4K Speakers Replacement: 手順 9、 3の画像 3
    • Disconnect the ribbon cable from its insulation-displacement connector by flipping up the black plastic clip.
    • Gently pull the ribbon cable out of its insulation-displacement connector.
  10. ACN Iris WG4K Speakers Replacement, Speakers: 手順 10、 3の画像 1 ACN Iris WG4K Speakers Replacement, Speakers: 手順 10、 3の画像 2 ACN Iris WG4K Speakers Replacement, Speakers: 手順 10、 3の画像 3
    • Disconnect the two white 2-pin JST connectors from the keypad/speaker circuit board by tugging gently until they release.
  11. ACN Iris WG4K Speakers Replacement: 手順 11、 2の画像 1 ACN Iris WG4K Speakers Replacement: 手順 11、 2の画像 2
    • The red markers indicate the four plastic clips arranged around the base of each speaker housing.
    • Use a plastic spudger to push in the four plastic clips.
  12. ACN Iris WG4K Speakers Replacement: 手順 12、 2の画像 1 ACN Iris WG4K Speakers Replacement: 手順 12、 2の画像 2
    • Once both speakers have been unclipped, gently pull the wire through the housing .
  13. ACN Iris WG4K Speakers Replacement: 手順 13、 3の画像 1 ACN Iris WG4K Speakers Replacement: 手順 13、 3の画像 2 ACN Iris WG4K Speakers Replacement: 手順 13、 3の画像 3
    • Use the Phillips #0 Screwdriver to remove the two Phillips head screws (6 mm)
    • Gently lift up the black cover to expose the now freed speaker.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Itze Kenney
メンバー登録日: 02/14/17
1,066 ポイント
9のガイドは作成済み
チーム
USF Tampa, Team 20-4, Remmell Spring 2017 USF Tampa, Team 20-4, Remmell Spring 2017人のメンバー
USFT-REMMELL-S17S20G4
4 メンバー
20のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 239
