はじめに
The blade connector helps transmit power from the lower half of the ACN Iris WG4K body to the upper half. If there is glitchy power on your video screen, check to see if blade connector is properly plugged in and working correctly.
必要な工具と部品
Press upwards with your index finger on the 4P4C connector as shown in the image.
Pull the connector gently out of its socket.
Flip the main body of the video phone so that the bottom is facing up.
Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
