はじめに
This is a guide for the full replacement of an ACER Aspire V5 laptop's touchpad.
必要な工具と部品
Close the laptop and flip over. Locate battery slide release. This guide marks the location with a red circle.
Use a pointed tool (we used a screwdriver) to slide release to the right when facing the laptop from the non-battery side.
Gently pull the battery away from the laptop with the slide release held open.
Slide a Jimmy tool between the top of the keyboard and the outer panel, then gently pop the top tabs out of place.
Carefully detach the two flex cables before fully lifting keyboard out in order to avoid cable damage.
Once cables are safely detached, lift the keyboard off of the laptop and place it on a safe, non-static surface.
