メインコンテンツにスキップ
ACER Aspire V5-571P-6609 Keyboard Replacement
必要な工具と部品
  1. ACER Aspire V5-571P-6609 Keyboard Replacement, Keyboard: 手順 1、 3の画像 1 ACER Aspire V5-571P-6609 Keyboard Replacement, Keyboard: 手順 1、 3の画像 2 ACER Aspire V5-571P-6609 Keyboard Replacement, Keyboard: 手順 1、 3の画像 3
    • Remember to apply anti-static measures. Power off the laptop completely. Remove the battery by turning laptop over and laying flat on a non-static surface. Note the location of the sliding battery release seen here.
    • Using a screwdriver or similar tool, slide release latch to the left to release the battery.
    • Once battery is released by the latch, gently pull battery away from main body of laptop.
  2. ACER Aspire V5-571P-6609 Keyboard Replacement: 手順 2、 1の画像 1
    • Remove the two Phillips #0 screws.
    • Flip the laptop right side up and open the lid.
  3. ACER Aspire V5-571P-6609 Keyboard Replacement: 手順 3、 2の画像 1 ACER Aspire V5-571P-6609 Keyboard Replacement: 手順 3、 2の画像 2
    • Open the laptop and place on flat, non-static surface. Using your Jimmy tool, slide the edge of the tool between the top of the keyboard and the outer panel and gently pop top tabs out of place. Remember to carefully detach the two flex cables before fully lifting keyboard out in order to avoid cable damage.
  4. ACER Aspire V5-571P-6609 Keyboard Replacement: 手順 4、 1の画像 1
    • Remember to reattach the two flex cables on the back of the keyboard to these ports during reassembly. The larger will fit in the white port on the right and the smaller backlight cable will fit in the smaller port to the immediate left of the white port.
終わりに
To reassemble your device, place keyboard back into place by gently inserting bottom tabs downward and away from display, and popping top tabs back into place with a small amount of pressure. Reinsert battery by gently pushing battery back into place.
作成者
1人の作成者と共同作成されました。
Kevin Sipple
メンバー登録日: 08/25/22
355 ポイント
2のガイドは作成済み
チーム
Gateway, Team 1-1, Pee Fall 2022 Gateway, Team 1-1, Pee Fall 2022人のメンバー
GCC-PEE-F22S1G1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 119
