メインコンテンツにスキップ
ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement
必要な工具と部品
  1. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement, Battery: 手順 1、 1の画像 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip your laptop over so the back panel is facing upwards.
    • Locate the lock switch below the battery.
  2. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 手順 2、 3の画像 1 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 手順 2、 3の画像 2 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 手順 2、 3の画像 3
    • Slide the lock switch to the right using your finger or a spudger.
    • At the same time, grasp the battery with your other hand and slide it out of the laptop.
    • Remove the battery.
    • To reinsert or replace the battery, simply line up the tabs on the battery with the laptop and slide it straight back in. There is no need to move the lock switch.
  3. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement, Hard Drive (HDD): 手順 3、 1の画像 1
    • Unscrew the one 8mm Phillips #0 screw from the bottom panel.
  4. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 手順 4、 3の画像 1 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 手順 4、 3の画像 2 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 手順 4、 3の画像 3
    • Remove the back panel by carefully disengaging it around the edges and then pulling upwards.
  5. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 手順 5、 1の画像 1
    • Remove the other 8mm Phillips #0 screw holding the hard drive to the rest of the laptop.
  6. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 手順 6、 2の画像 1 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 手順 6、 2の画像 2
    • Slide the hard drive to the left using a plastic opening tool.
  7. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 手順 7、 3の画像 1 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 手順 7、 3の画像 2 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: 手順 7、 3の画像 3
    • To remove the hard drive, pull up and to the left using the plastic tab as shown on the left side of the hard drive.
終わりに
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Cody Lim
メンバー登録日: 01/25/17
1,404 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 9-6, Banghart Winter 2017 Cal Poly, Team 9-6, Banghart Winter 2017人のメンバー
CPSU-BANGHART-W17S9G6
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 17
今までの合計 3,599
