メインコンテンツにスキップ
8BitDo SN30 Pro Gamepad Analog Stick Cap Replacement
必要な工具と部品
  1. 8BitDo SN30 Pro Gamepad Analog Stick Cap Replacement, Unscrew the Back Panel: 手順 1、 2の画像 1 8BitDo SN30 Pro Gamepad Analog Stick Cap Replacement, Unscrew the Back Panel: 手順 1、 2の画像 2
    • Place the controller face down on a solid surface.
    • Remove the five T6 Torx screws that hold the back panel in place.
  2. 8BitDo SN30 Pro Gamepad Analog Stick Cap Replacement, Lift the Back Panel: 手順 2、 3の画像 1 8BitDo SN30 Pro Gamepad Analog Stick Cap Replacement, Lift the Back Panel: 手順 2、 3の画像 2 8BitDo SN30 Pro Gamepad Analog Stick Cap Replacement, Lift the Back Panel: 手順 2、 3の画像 3
    • Lift the back panel, starting along the top edge of the controller.
    • There are two notches along the bottom edge that help keep the front and back panels together. This will be useful during reassembly.
  3. 8BitDo SN30 Pro Gamepad Analog Stick Cap Replacement, Remove the Battery: 手順 3、 3の画像 1 8BitDo SN30 Pro Gamepad Analog Stick Cap Replacement, Remove the Battery: 手順 3、 3の画像 2 8BitDo SN30 Pro Gamepad Analog Stick Cap Replacement, Remove the Battery: 手順 3、 3の画像 3
    • Use a spudger to pry the battery out from its compartment.
    • The battery is secured by double-sided foam adhesive. Be gentle and take your time to avoid damaging the battery.
    • Set aside the battery.
    • Be careful not to pull on the wires!
    • The ribbon that connects the analog board to the main controller board is now accessible.
  4. 8BitDo SN30 Pro Gamepad Analog Stick Cap Replacement, Unscrew the Analog Board: 手順 4、 2の画像 1 8BitDo SN30 Pro Gamepad Analog Stick Cap Replacement, Unscrew the Analog Board: 手順 4、 2の画像 2
    • Unscrew the four #0 Phillips screws that hold the analog board in place.
  5. 8BitDo SN30 Pro Gamepad Analog Stick Cap Replacement, Lift the Analog Board: 手順 5、 3の画像 1 8BitDo SN30 Pro Gamepad Analog Stick Cap Replacement, Lift the Analog Board: 手順 5、 3の画像 2 8BitDo SN30 Pro Gamepad Analog Stick Cap Replacement, Lift the Analog Board: 手順 5、 3の画像 3
    • Lift the analog board assembly by holding onto the edges of the board.
    • You may need to guide the analog sticks to clear the holes in the front panel while lifting the assembly.
    • Be careful not to pull on the ribbon!
    • Flip the board over so that the analog sticks are now facing upwards. Set it above the controller.
  6. 8BitDo SN30 Pro Gamepad Analog Stick Cap Replacement, Remove the Old Analog Stick Caps: 手順 6、 2の画像 1 8BitDo SN30 Pro Gamepad Analog Stick Cap Replacement, Remove the Old Analog Stick Caps: 手順 6、 2の画像 2
    • Hold the analog board assembly along the edges, and carefully pull out the old analog stick caps one-by-one.
  7. 8BitDo SN30 Pro Gamepad Analog Stick Cap Replacement, Install the New Caps: 手順 7、 2の画像 1 8BitDo SN30 Pro Gamepad Analog Stick Cap Replacement, Install the New Caps: 手順 7、 2の画像 2
    • Note the shape of the hole under the replacement analog stick cap and how it matches the shape of the analog stick shaft. Orient them correctly for a proper fit.
    • Take your new caps and push them into the shaft.
    • Push the cap all the way down until you hear a ‘click’, which is the analog button being pressed.
    • Make sure that the analog shaft stays straight and centered while you are pushing down on the cap.
    • The replacement caps sent by 8BitDo seem to be a newer, better silicon-coated variant, instead of the old caps that used rubber.
終わりに
13 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Jose Olarte III
メンバー登録日: 02/15/17
539 ポイント
1ガイドが承認済み
15 件のコメント
Great tutorial, but you don't need to remove the battery.
Filipe - 返信
Thanks for the comment! Yes, you can get away with not removing the battery, but you’ll need to be extra careful with that ribbon. I just didn’t want to introduce that risk of accidentally tugging (and potentially damaging) the ribbon, especially since it’s not in plain view unless the battery is removed.
Jose Olarte III -
Thanks for this but do you know how to unclip the stick mechanism from the board? I seemed to have broken one. The button is not “clicking” on press right. I have reached out to 8bitdo on how to order replacements. I figured I would try and see if I could just reseat it and maybe that would fix the issue but can’t get the stick off the board.
Thanks.
Dave Driscoll - 返信
I haven’t tried it myself, but from what I’ve seen, you may need to desolder the metal casing to get to the stick itself. If 8BitDo did send replacements, I would assume they’d send a whole assembly (both sticks + the board they’re soldered to). Please let us know if they get back to you; i’m very much curious. Thanks!
Jose Olarte III -
Great tutorial thanks!
Sammael Abaddon - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 54
過去 30 日: 240
今までの合計 20,060
