メインコンテンツにスキップ
8BitDo SN30 Pro+ Controller Rumble Motors Replacement
必要な工具と部品
  1. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Battery: 手順 1、 3の画像 1 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Battery: 手順 1、 3の画像 2 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Battery: 手順 1、 3の画像 3
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
  2. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Trigger Buttons: 手順 2、 2の画像 1 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Trigger Buttons: 手順 2、 2の画像 2
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
  3. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Screws: 手順 3、 2の画像 1 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Screws: 手順 3、 2の画像 2
    この手順で使用する道具:
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
  4. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Unclip Covers: 手順 4、 3の画像 1 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Unclip Covers: 手順 4、 3の画像 2 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Unclip Covers: 手順 4、 3の画像 3
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
  5. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Separate Covers: 手順 5、 1の画像 1
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
  6. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Ribbon Cable: 手順 6、 3の画像 1 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Ribbon Cable: 手順 6、 3の画像 2 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Ribbon Cable: 手順 6、 3の画像 3
    • Unlock the ribbon cable by push open the black plastic tab.
    • The tab will slide about 1.5mm
    • Pull the ribbon cable out of the connector in the direction of the cable.
  7. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Caps: 手順 7、 2の画像 1 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Caps: 手順 7、 2の画像 2
    • Grab the top and pull straight up on the joystick cap. Pulling out the caps one-by-one.
  8. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Screws: 手順 8、 3の画像 1 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Screws: 手順 8、 3の画像 2 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Remove Screws: 手順 8、 3の画像 3
    • Use a Phillips screwdriver to remove the nine 5.2 mm screws securing the rear circuit board.
    • Four around the Right stick
    • Four around the Left stick
    • One next to the Battery connector
  9. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Separate Rear Board: 手順 9、 3の画像 1 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Separate Rear Board: 手順 9、 3の画像 2 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Separate Rear Board: 手順 9、 3の画像 3
    • Pull the two rumble motors out of their housings.
    • Grab the analog sticks to pull out the circuit board
  10. 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Desolder Rumble Motors: 手順 10、 3の画像 1 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Desolder Rumble Motors: 手順 10、 3の画像 2 8BitDo SN30 Pro+ Controller Rumble Motors Replacement, Desolder Rumble Motors: 手順 10、 3の画像 3
    • Flip over the rear board
    • Using a soldering iron to desolder the rumble motor wires.
    • During reassembly, remember to solder the wires back into the same position.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Brian W
メンバー登録日: 12/21/11
1,773 ポイント
8のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 18
今までの合計 765
