メインコンテンツにスキップ
8BitDo SN30 Pro+ Controller Joystick Caps Replacement
必要な工具と部品
  1. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Battery: 手順 1、 3の画像 1 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Battery: 手順 1、 3の画像 2 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Battery: 手順 1、 3の画像 3
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
  2. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Trigger Buttons: 手順 2、 2の画像 1 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Trigger Buttons: 手順 2、 2の画像 2
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
  3. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Screws: 手順 3、 2の画像 1 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Screws: 手順 3、 2の画像 2
    この手順で使用する道具:
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
  4. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Unclip Covers: 手順 4、 3の画像 1 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Unclip Covers: 手順 4、 3の画像 2 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Unclip Covers: 手順 4、 3の画像 3
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
  5. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Separate Covers: 手順 5、 1の画像 1
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
  6. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Caps: 手順 6、 3の画像 1 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Caps: 手順 6、 3の画像 2 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Remove Caps: 手順 6、 3の画像 3
    • Grab the top and pull straight up on the joystick cap. Pulling out the caps one-by-one.
  7. 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Installing New Caps: 手順 7、 3の画像 1 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Installing New Caps: 手順 7、 3の画像 2 8BitDo SN30 Pro+ Controller Joystick Caps Replacement, Installing New Caps: 手順 7、 3の画像 3
    • One at a time, Orient the new cap to match the analog stick.
    • Push the cap straight down onto the analog stick.
    • You should hear the click of the stick button
終わりに
11 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Brian W
メンバー登録日: 12/21/11
1,773 ポイント
8のガイドは作成済み
5件のガイドコメント
Was wondering, does other brand joystick cap other than 8bitdo (eg:ps4, ps5, xbox one) fits ?
Lee Han Chang - 返信
looks like PS5 hole size and cone shape. Confirmation needed.
Gustavo Klein Martins -
I did the repair with a third party analog cap meant for the PS5 (being extra cheap) on the Pro 2. Despite the bottom hole being bigger on the original, the replacement joystick fit right in.
TorxT6 -
Did you manage to find a replacement? Looking for an alternative as well since 8bitdo doesn't ship here.
Joseph Johansson - 返信
Hello Joseph, I've purchased my replacements from Core Electronics with no issues, how ever they are based in Australia so unsure if they will ship to where you need them.
Darryn Stanmore -
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 33
過去 30 日: 152
今までの合計 5,042
