メインコンテンツにスキップ
3DR Solo Leg Replacement
必要な工具と部品
  1. 3DR Solo Leg Replacement, Propeller: 手順 1、 1の画像 1
    • Grip the arm, which is located underneath the propeller, with one hand, and with your dominant hand grip the center of the propeller.
  2. 3DR Solo Leg Replacement: 手順 2、 1の画像 1
    • Twist the propeller from the locked to unlocked position as indicated by the images of the lock.
    • You will need to twist in this direction for 2-3 full rotations before the propeller will detach.
  3. 3DR Solo Leg Replacement: 手順 3、 1の画像 1
    • Lift the propeller off the motor.
    • To remove the silver-top propellers, repeat these steps, turning the propellers in the opposite direction of the black-top propellers.
  4. 3DR Solo Leg Replacement, Leg: 手順 4、 1の画像 1
    • Place the controller on a flat surface with the battery side down.
  5. 3DR Solo Leg Replacement: 手順 5、 3の画像 1 3DR Solo Leg Replacement: 手順 5、 3の画像 2 3DR Solo Leg Replacement: 手順 5、 3の画像 3
    • Locate the leg and remove the two 10mm screws that hold the leg in place.
  6. 3DR Solo Leg Replacement: 手順 6、 1の画像 1
    • Gently pull the leg up to remove it from its position.
    • Leg should be connected by a black wire.
  7. 3DR Solo Leg Replacement: 手順 7、 3の画像 1 3DR Solo Leg Replacement: 手順 7、 3の画像 2 3DR Solo Leg Replacement: 手順 7、 3の画像 3
    • Locate the rubber grip at the end of the leg and, with your thumb, peel it back and pull it off.
  8. 3DR Solo Leg Replacement: 手順 8、 2の画像 1 3DR Solo Leg Replacement: 手順 8、 2の画像 2
    • Leg type 1 will contain a 1mm screw at the base of the leg.
    • Unscrew the 1mm screw located at the end of the leg.
  9. 3DR Solo Leg Replacement: 手順 9、 1の画像 1
    • Gently pull the black cord up to release it from the leg.
  10. 3DR Solo Leg Replacement: 手順 10、 3の画像 1 3DR Solo Leg Replacement: 手順 10、 3の画像 2 3DR Solo Leg Replacement: 手順 10、 3の画像 3
    • Leg type 2 will contain the antenna wire.
    • Gently pull up on and remove the plastic covering labeled "solo antenna".
    • Locate the antenna wire and carefully pull up and remove it.
    • The antenna wire is flimsy so use caution upon removal.
終わりに
作成者
3人の作成者と共同で作成されました。
Leia Harlow
メンバー登録日: 09/11/17
104 ポイント
1ガイドが承認済み
チーム
CSU Fullerton, Team S2-G3, Bruce Fall 2017 CSU Fullerton, Team S2-G3, Bruce Fall 2017人のメンバー
CSUF-BRUCE-F17S2G3
4 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 429
