メインコンテンツにスキップ
3DR Solo Gimbal Replacement
必要な工具と部品
  1. 3DR Solo Gimbal Replacement, Propeller: 手順 1、 1の画像 1
    • Grip the arm, which is located underneath the propeller, with one hand, and with your dominant hand grip the center of the propeller.
  2. 3DR Solo Gimbal Replacement: 手順 2、 1の画像 1
    • Twist the propeller from the locked to unlocked position as indicated by the images of the lock.
    • You will need to twist in this direction for 2-3 full rotations before the propeller will detach.
  3. 3DR Solo Gimbal Replacement: 手順 3、 1の画像 1
    • Lift the propeller off the motor.
    • To remove the silver-top propellers, repeat these steps, turning the propellers in the opposite direction of the black-top propellers.
  4. 3DR Solo Gimbal Replacement, Gimbal: 手順 4、 1の画像 1
    • Lay the drone flat with the side containing the gimbal face up.
  5. 3DR Solo Gimbal Replacement: 手順 5、 1の画像 1
    • Locate the three, 11mm screws surrounding the gimbal.
    • There should be a screw to the left, right, and one directly in the front of the gimbal.
  6. 3DR Solo Gimbal Replacement: 手順 6、 1の画像 1
    • Using the J1 Phillips Head Screwdriver, unscrew each 11mm screw surrounding the gimbal.
    • Turn the driver in a counter-clockwise direction for each screw.
    • Note that the screws will loosen, but will not come out of their sockets completely.
    • Once all three screws are loosened, use the smaller, plastic opening tool to carefully lift the panel that encases the gimbal by placing the square shaped end of the opening tool into the crevice between the panel and the rest of the device.
    • Be sure that the end of the opening tool is facing inward, towards the screws.
  7. 3DR Solo Gimbal Replacement: 手順 8、 1の画像 1
    • Gently begin lifting the panel with the opening tool by moving your hand in a downward motion, causing the panel to lift from the device.
    • Work your way around the entire square panel doing this same motion until it is loose enough for you to pull off with your hand.
  8. 3DR Solo Gimbal Replacement: 手順 9、 3の画像 1 3DR Solo Gimbal Replacement: 手順 9、 3の画像 2 3DR Solo Gimbal Replacement: 手順 9、 3の画像 3
    • Once the gimbal and panel is loose enough to pull off with your hand, gently remove both the panel and the gimbal from the device.
    • When doing this, be sure to leave the micro SD cable inside the device.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Aimee
メンバー登録日: 09/11/17
167 ポイント
1ガイドが承認済み
チーム
CSU Fullerton, Team S2-G3, Bruce Fall 2017 CSU Fullerton, Team S2-G3, Bruce Fall 2017人のメンバー
CSUF-BRUCE-F17S2G3
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 15
今までの合計 1,334
