はじめに
This guide walks you through how to replace the SD memory card on a 360fly 4K camera.
必要な工具と部品
Flip the camera upside down and peel off the two plastic screw covers with the metal spudger to reveal the screws.
Remove the five 4 mm screws around the battery assembly with a T4 screwdriver.
Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool.
Press the battery from the back of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
Gently pry the plug from the motherboard and remove the motherboard from the assembly.
5 の人々がこのガイドを完成させました。
