はじめに
A positive crankcase ventilation (PCV) plate increases the longevity of your oil by reusing unburnt gas. It is also required for emissions. When installing your PCV plate, there could be a faulty gasket creating an oil leak. If you notice an oil leak coming from your PCV plate, there is a good chance it is because the gasket isn’t sealing properly. This guide will walk you through how to properly replace the gasket.
必要な工具と部品
4 の人々がこのガイドを完成させました。
