はじめに
In 2019, Ford announced that it would stop production of the Ford Fiesta model line. However, the Ford Fiesta model is still popular in the UK and was ranked as the bestselling new and used car of 2019. Also, the average labor for fixing headlights is estimated between $50 and $63 dollars while parts are only priced at $19 dollars. This means that fixing the bulbs at home will be cheaper than going to the mechanic to get them fixed. Our goal is not only to save you money but to create a guide to help fix your 2016 Ford Fiesta S in confidence without replacing your car to prevent waste.
Please make sure that you do not open your hood when there are high winds. Verify that the handbrake is on and the ignition is off and wait 10 minutes for the engine to cool before opening the hood.
必要な工具と部品
Locate the release hatch and pull it towards you.
Lift the hood slightly and feel for the release catch, then slide it to the left.
Lift the hood and prop it up with the strut.
3 の人々がこのガイドを完成させました。
2 件のコメント
buen tutorial, estaria excelente agregar un video, gracias por el aporte
