メインコンテンツにスキップ
2015 Nissan Pathfinder Rear Windshield Wiper Replacement
必要な工具と部品
  1. 2015 Nissan Pathfinder Rear Windshield Wiper Replacement, Rear Windshield Wiper: 手順 1、 2の画像 1 2015 Nissan Pathfinder Rear Windshield Wiper Replacement, Rear Windshield Wiper: 手順 1、 2の画像 2
    • Gently life the wiper up and away from the windshield in an upright position.
  2. 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: 手順 2、 2の画像 1 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: 手順 2、 2の画像 2
    • Using your finger and thumb, lift the wiper blade upward from the base.
    • The wiper should be sticking out and away from the windshield.
  3. 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: 手順 3、 3の画像 1 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: 手順 3、 3の画像 2 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: 手順 3、 3の画像 3
    • Locate the pivot block at the end of the wiper arm that connects to the blade.
    • Pull the blade away with adequate force to remove the blade completely.
  4. 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: 手順 4、 1の画像 1
    • Acquire the replacement blade and remove the rubber yellow protector.
  5. 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: 手順 5、 3の画像 1 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: 手順 5、 3の画像 2 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: 手順 5、 3の画像 3
    • Locate the thin notch in the center of the replacement blade.
    • Locate the corresponding rounded port on the wiper arm.
    • Insert the notch into the arm and push together with mild force to attach the wiper blade to the arm.
    • When attaching the wiper blade to the arm, a clicking sound should be heard to ensure it is correctly assembled.
  6. 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: 手順 6、 3の画像 1 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: 手順 6、 3の画像 2 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: 手順 6、 3の画像 3
    • Gently fold the blade in and lay the wiper blade and arm back down on the windshield.
ゴール
作成者
1人の作成者と共同作成されました。
Katie
メンバー登録日: 08/16/23
133 ポイント
1ガイドが承認済み
チーム
University of North Alabama, Team A-2, Winner Fall 2023 University of North Alabama, Team A-2, Winner Fall 2023人のメンバー
UNA-WINNER-F23SAG2
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 16
今までの合計 95
