メインコンテンツにスキップ
2015-2019 Dodge Charger Tail Light Replacement
必要な工具と部品
  1. 2015-2019 Dodge Charger Tail Light Replacement, Tail Light: 手順 1、 1の画像 1
    • Remove the rear plastic panel cover located inside the trunk by pushing the panel towards the center of the car.
  2. 2015-2019 Dodge Charger Tail Light Replacement: 手順 2、 2の画像 1 2015-2019 Dodge Charger Tail Light Replacement: 手順 2、 2の画像 2
    • Remove the plastic screw securing the inner lining of the trunk by pulling outwards.
    • Do not use excess force as it can damage the screw.
  3. 2015-2019 Dodge Charger Tail Light Replacement: 手順 3、 2の画像 1 2015-2019 Dodge Charger Tail Light Replacement: 手順 3、 2の画像 2
    • Remove the plastic pin by prying it outwards using a pry bar to free the inner lining.
    • Pull back the inner lining to gain access to the screws securing the tail lights in place.
  4. 2015-2019 Dodge Charger Tail Light Replacement: 手順 4、 3の画像 1 2015-2019 Dodge Charger Tail Light Replacement: 手順 4、 3の画像 2 2015-2019 Dodge Charger Tail Light Replacement: 手順 4、 3の画像 3
    • Remove both 8 mm nuts securing the tail lights in place using an 8 mm wrench.
    • Remove the nuts carefully as they may fall between the gaps which can be difficult to reach.
  5. 2015-2019 Dodge Charger Tail Light Replacement: 手順 5、 1の画像 1
    • Remove the connector by squeezing both sides and pulling outwards.
  6. 2015-2019 Dodge Charger Tail Light Replacement: 手順 6、 2の画像 1 2015-2019 Dodge Charger Tail Light Replacement: 手順 6、 2の画像 2
    • Remove the plastic cover by pulling outwards so that the tail light can slide out.
  7. 2015-2019 Dodge Charger Tail Light Replacement: 手順 7、 2の画像 1 2015-2019 Dodge Charger Tail Light Replacement: 手順 7、 2の画像 2
    • Grab both sides of the tail light firmly and pull it out.
  8. 2015-2019 Dodge Charger Tail Light Replacement: 手順 8、 1の画像 1
    • Slide the replacement tail light back in firmly.
  9. 2015-2019 Dodge Charger Tail Light Replacement: 手順 9、 3の画像 1 2015-2019 Dodge Charger Tail Light Replacement: 手順 9、 3の画像 2 2015-2019 Dodge Charger Tail Light Replacement: 手順 9、 3の画像 3
    • Insert the connector back to the tail light.
    • Screw the 8 mm nuts onto the bolts by hand before tightening with a 8 mm wrench.
  10. 2015-2019 Dodge Charger Tail Light Replacement: 手順 10、 3の画像 1 2015-2019 Dodge Charger Tail Light Replacement: 手順 10、 3の画像 2 2015-2019 Dodge Charger Tail Light Replacement: 手順 10、 3の画像 3
    • Push the plastic pin back into the hole to secure the side inner lining.
    • Push the plastic screw back into the hole to secure the bottom inner lining.
    • Push the rear plastic panel cover back on.
  11. 2015-2019 Dodge Charger Tail Light Replacement: 手順 11、 1の画像 1
    • Start the vehicle to test if the tail light works.
終わりに
Repeat the same steps to replace the other tail light.
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Asad Raza
メンバー登録日: 01/17/22
217 ポイント
1ガイドが承認済み
チーム
York University, Team 1-23, O'Regan Winter 2022 York University, Team 1-23, O'Regan Winter 2022人のメンバー
YORK-O'REGAN-W22S1G23
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 26
過去 30 日: 99
今までの合計 3,938
