はじめに
This is a guide to replacing the air filters on the 11th-generation Toyota Corollas (2014-2016). Air filters are an essential piece in an engine, as they serve as the lungs of your car's engine by conducting clean air into your car. In some cases, this can help fix some performance issues and improve performance overall.
必要な工具と部品
Open the hood of your Corolla by pulling the hinge at the bottom of your dash and hold it up using the hood lift support.
Pull the hinge in the lower part of your driver-side dashboard. It should have an icon of a vehicle with its hood up.
Once you pull it, open up the hood and use the support located at the center of the engine bay to hold the hood up.
Congratulations, you have replaced the air filter in your Corolla.
ある他の人がこのガイドを完成しました。
