メインコンテンツにスキップ
2013 Toyota Camry Rear Brake Light Bulb Replacement
必要な工具と部品
  1. 2013 Toyota Camry Rear Brake Light Bulb Replacement, Rear Brake Light Bulb Replacement: 手順 1、 1の画像 1
    • Be sure that your car is completely turned off.
    • Pop the trunk open.
  2. 2013 Toyota Camry Rear Brake Light Bulb Replacement: 手順 2、 3の画像 1 2013 Toyota Camry Rear Brake Light Bulb Replacement: 手順 2、 3の画像 2 2013 Toyota Camry Rear Brake Light Bulb Replacement: 手順 2、 3の画像 3
    • Use a spudger to pry out the two smaller fasteners inside the trunk.
    • Push on the hook fastener to remove it.
  3. 2013 Toyota Camry Rear Brake Light Bulb Replacement: 手順 3、 2の画像 1 2013 Toyota Camry Rear Brake Light Bulb Replacement: 手順 3、 2の画像 2
    • Peel back the canvas on the side where you are replacing the bulb.
    • You will begin to see the cables connected to the rear light.
  4. 2013 Toyota Camry Rear Brake Light Bulb Replacement: 手順 4、 1の画像 1
    • You will see three connections; a brake light, a turn signal light, and a parking light.
    • The one we will be replacing is the brake light bulb, the biggest connection of the three.
  5. 2013 Toyota Camry Rear Brake Light Bulb Replacement: 手順 5、 2の画像 1 2013 Toyota Camry Rear Brake Light Bulb Replacement: 手順 5、 2の画像 2
    • Turn the bulb counterclockwise from the outer connection portion (the black part).
    • Pull the old light bulb from its connection.
    • This may be a bit difficult to pull apart, but not tools are required.
  6. 2013 Toyota Camry Rear Brake Light Bulb Replacement: 手順 6、 3の画像 1 2013 Toyota Camry Rear Brake Light Bulb Replacement: 手順 6、 3の画像 2 2013 Toyota Camry Rear Brake Light Bulb Replacement: 手順 6、 3の画像 3
    • Before handling the new light bulb, wear latex gloves or something to cover your hands. Handling the bulb with bare hands will shorten the light bulb's life span.
    • Plug the new light bulb into the connection by pushing until you hear a click.
  7. 2013 Toyota Camry Rear Brake Light Bulb Replacement: 手順 7、 3の画像 1 2013 Toyota Camry Rear Brake Light Bulb Replacement: 手順 7、 3の画像 2 2013 Toyota Camry Rear Brake Light Bulb Replacement: 手順 7、 3の画像 3
    • Place the connection into its slot and turn it clockwise to ensure it stays in place.
    • Follow Steps 2 and 3 in reverse.
ゴール
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Chris
メンバー登録日: 11/14/22
170 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 2-40, Briggs Fall 2022 CSU Los Angeles, Team 2-40, Briggs Fall 2022人のメンバー
CSULA-BRIGGS-F22S2G40
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 49
今までの合計 932
