メインコンテンツにスキップ
2013 Kia Forte Wheel Replacement
必要な工具と部品
  1. 2013 Kia Forte Wheel Replacement, Wheel: 手順 1、 1の画像 1
    • Open trunk. Most 2013 models do not have a trunk button on the remote. In order to open trunk, hold down unlock button.
  2. 2013 Kia Forte Wheel Replacement: 手順 2、 3の画像 1 2013 Kia Forte Wheel Replacement: 手順 2、 3の画像 2 2013 Kia Forte Wheel Replacement: 手順 2、 3の画像 3
    • Remove the three trunk mats, shown in order.
    • The bottom, hard plastic mat serves as a surface to lay on, if need, whilst changing tire.
  3. 2013 Kia Forte Wheel Replacement: 手順 3、 1の画像 1
    • Spare tire and tools needed to change tire are located under the trunk mats.
    • The jack and lug wrench are placed in a styrofoam container on top of the spare tire.
  4. 2013 Kia Forte Wheel Replacement: 手順 4、 2の画像 1 2013 Kia Forte Wheel Replacement: 手順 4、 2の画像 2
    • Turning counterclockwise, unscrew and remove plastic place holder in center of spare tire.
  5. 2013 Kia Forte Wheel Replacement: 手順 5、 2の画像 1 2013 Kia Forte Wheel Replacement: 手順 5、 2の画像 2
    • Loosen lug nuts turning counterclockwise, one turn each.
    • Do not loosen lug nuts by circling the tire. Loosen them first in the 1, 3 and 5 positions (shown in red circles; the '1' position pointing north). After loosening the 1, 3 and 5 positions, loosen 2 and 4.
    • Do not completely remove ANY lug nuts until tire is raised from ground.
  6. 2013 Kia Forte Wheel Replacement: 手順 6、 2の画像 1 2013 Kia Forte Wheel Replacement: 手順 6、 2の画像 2
    • Place jack under jack plate, under appropriate tire.
    • Jack plates are welded to frame with two tabs and raised dots to indicate index with jack.
  7. 2013 Kia Forte Wheel Replacement: 手順 7、 3の画像 1 2013 Kia Forte Wheel Replacement: 手順 7、 3の画像 2 2013 Kia Forte Wheel Replacement: 手順 7、 3の画像 3
    • Insert jack hook into loop on jack.
    • Insert end of jack hook into lug wrench.
    • To raise vehicle turn the lug wrench, attached to jack hook, clockwise. Turn until tire is one inch (approximately 30mm) off ground.
  8. 2013 Kia Forte Wheel Replacement: 手順 8、 3の画像 1 2013 Kia Forte Wheel Replacement: 手順 8、 3の画像 2 2013 Kia Forte Wheel Replacement: 手順 8、 3の画像 3
    • Once tire is elevated, remove lug nuts by hand.
    • Be aware that the tire will shift as lug nuts are removed.
    • After removing lug nuts, carefully take tire off of frame.
  9. 2013 Kia Forte Wheel Replacement: 手順 9、 2の画像 1 2013 Kia Forte Wheel Replacement: 手順 9、 2の画像 2
    • Place spare tire onto frame.
    • Hand tighten lug nuts (the 1, 3 and 5 positions first) until secure.
  10. 2013 Kia Forte Wheel Replacement: 手順 10、 2の画像 1 2013 Kia Forte Wheel Replacement: 手順 10、 2の画像 2
    • Lower vehicle, turning jack counterclockwise, until tire touches ground.
    • Tighten lug nuts (again, beginning with the 1, 3 and 5 positions) with lug wrench until secure.
  11. 2013 Kia Forte Wheel Replacement: 手順 11、 1の画像 1
    • Congratulations, your tire is changed!
    • NOTE: obey the speed limitations of your spare tire. Exceeding the recommended speed is dangerous and can damage the spare.
ゴール
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Kaleb
メンバー登録日: 03/16/15
212 ポイント
1ガイドが承認済み
コメント 1 件
Anyone have anything to share about this vehicle?
Experience, maintenance and repair logs or experiences of note?
Thanks, ive just received this car and have been told its a good one. Have no prior experience with kias though.
2.0 cyclical engine.
RxMode - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 44
今までの合計 8,460
