はじめに
このガイドでは、2013 - 2017 Ford Escapeのキー・フォブのバッテリーの交換方法について説明します。 この手順ごとにまとめられたガイドを読めば、キー・フォブを簡単に修理し、使い続けることができます。 キーの修復に必要なものは、交換用のバッテリーだけです。 プロセスは簡単で、数分で完成します。
必要な工具と部品
FORDロゴを上に向けてイグニッションキーを左のノッチに差し込みます。
イグニッションキーを使用して古いバッテリーを取り外します。
デバイスを組み立て直すには、背面カバーをキー・フォブに戻してしっかり固定します。
36 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
16 件のコメント
Good job. The training aid was clear and lacked nothing. Even had the battery type and a buy function which is a nice touch.
Excellent guide, Thanks for the details
Thanks for the help! Glad I just happened to have a battery and easy to follow instructions.
Easy Cheesy Lemon Squeezy! Thanks for the assist!
Nice tutorial! Here’s a good link if you have other Escape year models: https://fobbattery.com/vehicles/ford/esc...
Thank you so so much! I have a 2014 ford escape and at the worst time ever, it decided to alert me my fob battery was low. (C’mon life!) Worst time ever: 2 ER visits in a month and my hands are numb and tingling and difficult to use! I just completed your excellent guide and the task is DONE and I don’t have to bother my husband! I buy my button cell batts on ebay in bulk….great prices there. Thank you so much!! If I can do it with my issues, anyone can!
I’m glad I found this help. I would not have realized to remove the metal key first. Thanks.
Cathy Hawn - 返信
The photo and description in steps 3 and 4 are misleading. Prying the notch as shown breaks the back cover sub assembly (Ford logo) instead of causing the back cover sub assembly to detach from the main fob body.
I found it easier to use my fingernail to pry around the joint between the back cover sub assembly and the main body to open the fob.
Once battery is replaced and the fob is closed, is there any (re)programming that needs to occur to sync the fob with the car?
Easy Peasy, Thank you!
For some reason I can’t get the cover to snap back together? The little “unlock button” you slide down to take apart the remote is down and won’t slide up to lock it together?
