メインコンテンツにスキップ
2012-Present Toyota Corolla Windshield Wiper Replacement
必要な工具と部品
  1. 2012-Present Toyota Corolla Windshield Wiper Replacement, Windshield Wiper: 手順 1、 2の画像 1 2012-Present Toyota Corolla Windshield Wiper Replacement, Windshield Wiper: 手順 1、 2の画像 2
    • Lift up the windshield wiper you're replacing.
  2. 2012-Present Toyota Corolla Windshield Wiper Replacement: 手順 2、 2の画像 1 2012-Present Toyota Corolla Windshield Wiper Replacement: 手順 2、 2の画像 2
    • Insert a flathead screwdriver into the locking mechanism of the wiper and gently pry it open.
    • You can use your car keys in case you do not have a screwdriver.
  3. 2012-Present Toyota Corolla Windshield Wiper Replacement: 手順 3、 2の画像 1 2012-Present Toyota Corolla Windshield Wiper Replacement: 手順 3、 2の画像 2
    • Push the wiper blade downwards until it locks into place.
  4. 2012-Present Toyota Corolla Windshield Wiper Replacement: 手順 4、 2の画像 1 2012-Present Toyota Corolla Windshield Wiper Replacement: 手順 4、 2の画像 2
    • Angle the wiper away from you, so that the top is near you while the bottom is farther away.
    • Gently push the blade out of the wiper base.
  5. 2012-Present Toyota Corolla Windshield Wiper Replacement: 手順 5、 2の画像 1 2012-Present Toyota Corolla Windshield Wiper Replacement: 手順 5、 2の画像 2
    • Bring the new wiper blade into the wiper base from the car, aiming it so that the wiper base enters the lock hole.
    • Once the wiper blade is in, hold it from the bottom and push it upwards to secure the hold.
    • Make sure to start with the lock open, and that the blade is facing the same direction as the picture.
  6. 2012-Present Toyota Corolla Windshield Wiper Replacement: 手順 6、 3の画像 1 2012-Present Toyota Corolla Windshield Wiper Replacement: 手順 6、 3の画像 2 2012-Present Toyota Corolla Windshield Wiper Replacement: 手順 6、 3の画像 3
    • Push down the lock with force until it clicks.
  7. 2012-Present Toyota Corolla Windshield Wiper Replacement: 手順 7、 1の画像 1
    • Repeat for the second blade.
    • Your windshield wiper blade replacement is now complete!
ゴール
作成者
2人の作成者と共同で作成されました。
Yusuf Gabaire
メンバー登録日: 07/03/21
157 ポイント
1ガイドが承認済み
チーム
York University, Team 2-6, O'Regan Fall 2021 York University, Team 2-6, O'Regan Fall 2021人のメンバー
YORK-O'REGAN-F21S2G6
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 41
過去 30 日: 188
今までの合計 2,579
