メインコンテンツにスキップ
2012-2015 Honda Civic Windshield Wiper Replacement
  1. 2012-2015 Honda Civic Windshield Wiper Replacement, Windshield Wipers: 手順 1、 1の画像 1
    • Carefully pull the wipers upwards, away from the windshield.
  2. 2012-2015 Honda Civic Windshield Wiper Replacement: 手順 2、 3の画像 1 2012-2015 Honda Civic Windshield Wiper Replacement: 手順 2、 3の画像 2 2012-2015 Honda Civic Windshield Wiper Replacement: 手順 2、 3の画像 3
    • Hold and press the first lever of the wiper arm down and put the wiper arm straight.
    • Pull the wiper up and slide the blade off of the arm.
    • Once the hook of the windshield looks like it went through the wiper, pull the wiper out leaving only the hook in place.
  3. 2012-2015 Honda Civic Windshield Wiper Replacement: 手順 3、 3の画像 1 2012-2015 Honda Civic Windshield Wiper Replacement: 手順 3、 3の画像 2 2012-2015 Honda Civic Windshield Wiper Replacement: 手順 3、 3の画像 3
    • To install the new wiper blades, slide the hook onto the top space.
    • Then attached the hook to the center space of the wiper.
    • Lastly, gently press the wiper downward listening for a "click" or other indication for the blade is locked in place.
  4. 2012-2015 Honda Civic Windshield Wiper Replacement: 手順 4、 1の画像 1
    • Turn on the wipers and test the new blades to make sure they are functioning correctly.
終わりに
Congratulations! You have successfully replaced the windshield wipers on your Honda Civic 2015. With this step-by-step guide, you were able to complete the process with ease and without having to spend extra money at a mechanic. Having properly functioning wipers is crucial for your safety while driving, especially during rainy and snowy weather conditions. Now that you have completed this guide, you have the knowledge and confidence to replace your wipers in the future. Remember to periodically check your wipers and replace them as needed to ensure your safety on the road. Thank you for using this guide and happy driving!
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Carlos Herrera
メンバー登録日: 05/04/23
130 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 2-5, Briggs Spring 2023 CSU Los Angeles, Team 2-5, Briggs Spring 2023人のメンバー
CSULA-BRIGGS-S23S2G5
2 メンバー
2のガイドは作成済み
コメント 1 件
Amazing work I now understand how to fix my windshield wipers :)
John Mejia - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 28
過去 30 日: 128
今までの合計 1,115
