メインコンテンツにスキップ
2012-2015 Honda Civic Taillight Turn Signal Replacement
必要な工具と部品
  1. 2012-2015 Honda Civic Taillight Turn Signal Replacement, Taillight Turn Signal: 手順 1、 2の画像 1 2012-2015 Honda Civic Taillight Turn Signal Replacement, Taillight Turn Signal: 手順 1、 2の画像 2
    • Ensure your car is turned off by checking that the key is in the off (O) position and that the engine is not running.
    • Open the trunk by pulling the latch on the floor of the driver's side.
  2. 2012-2015 Honda Civic Taillight Turn Signal Replacement: 手順 2、 2の画像 1 2012-2015 Honda Civic Taillight Turn Signal Replacement: 手順 2、 2の画像 2
    • In the trunk, remove these fasteners by prying the center piece out with the screwdriver.
    • Expose the bulbs by pulling the trunk lining away from the walls of the trunk.
  3. 2012-2015 Honda Civic Taillight Turn Signal Replacement: 手順 3、 2の画像 1 2012-2015 Honda Civic Taillight Turn Signal Replacement: 手順 3、 2の画像 2
    • Rotate the turn signal socket ¼ turn counterclockwise. The turn signal socket is located below the main taillight bulb and closer to the middle of the car.
    • You will be able to pull the socket out of its housing and expose the blown bulb.
  4. 2012-2015 Honda Civic Taillight Turn Signal Replacement: 手順 4、 2の画像 1 2012-2015 Honda Civic Taillight Turn Signal Replacement: 手順 4、 2の画像 2
    • Remove just the blown bulb from the socket. A bit of force might be required to get it separated, but once it is, just the bulb and its rectangular, flat base should remain.
    • Put the new bulb in.
終わりに
The fasteners are easiest to reinstall when the center piece is pulled as far out as possible when reinserting. Once they are back in place, press the center piece down to lock them in.
作成者
1人の作成者と共同作成されました。
Keaton Gilbert
メンバー登録日: 03/31/20
109 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team S4-G24, Willis Spring 2020 University of Memphis, Team S4-G24, Willis Spring 2020人のメンバー
UM-WILLIS-S20S4G24
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 19
過去 30 日: 88
今までの合計 3,104
