はじめに
Replacing your oil can be a rewarding and enjoyable process. With the necessary tools and parts anyone can conduct an oil change in their driveway.
必要な工具と部品
To reassemble your vehicle, follow these instructions in reverse order.
18 の人々がこのガイドを完成させました。
14 件のコメント
Have 2017 Subaru Forester. Book says nothing about removing panel to get to the oil plug and this instruction says nothing about removing the panel to get to the oil plug. Looks like I have to pry the panel off to get to the plug but will call Subaru later today to see what they say. Seems ridiculous to have a panel with 5 keepers that have to be removed every time you change the oil just to get to the oil plug and then say nothing in the book about removing the cover. Your instruction also needs updated regarding the oil plug cover on a 2017 Subaru Forester.
If the location of the oil pan and plug has changed, then a new guide should be created for 2017 models. This is labeled 2012-2016 because it applies to those model years. I'm not familiar with the panel under the 2017, so I can't provide any updates.
leaders or quarts of oil? My2016 forester calls for 5.1 quarts of oil
It's Quarts, not Liters. I had updated it in the tools a while ago but missed it in the step. Updated.
I have a lot of problems with all of my 2016 Forester manuals. They put numbers on the illustrations, but no numbers in the manual. My Sirius XM manual is at least 6 times thicker than the owner's manual. Why isn't there instructions on how to refill all the fluids in the maintenance manual. I don't need to take it to the dealer for everything!
