はじめに
This guide will show you how to change your Scion FR-S Oil and Oil Filter. Have oil and a replacement oil filter before starting. Be sure to check that the oil can handle the temperatures commonly found in your area.
必要な工具と部品
Place the portable vehicle ramps in front of either wheel and slowly pull the vehicle up onto them.
Put the vehicle in park and engage the parking brake.
Lie down under the front of the car and locate the oil drain plug in the opening on the skid plate.
Place the oil pan below the drain plug.
Remove the oil drain plug with the 14 mm socket wrench and let the oil drain into the drain pan.
Allow the oil to drain from the vehicle.
Once there is no more oil pouring out, reattach the oil drain plug with the 14 mm socket wrench until it is tight.
Screw the new oil filter in a clockwise rotation onto the same area where the old one was removed until it is tight.
Locate the oil fill cap that is beside the new filter and take it off. Then pour the oil in using the funnel.
Remove the funnel and firmly reattach the oil fill cap.
Slowly roll the vehicle off of the portable vehicle ramps.
Check the dipstick to make sure there is enough oil. The level indicated should be in-between the two metal dimples on the end of the dipstick.
Congratulations on changing the oil on your 2012-2016 Scion FR-S!
2 の人々がこのガイドを完成させました。
