メインコンテンツにスキップ
2012-2016 Honda CR-V Oil and Oil Filter Replacement
必要な工具と部品
  1. 2012-2016 Honda CR-V Oil and Oil Filter Replacement, Oil and Oil Filter: 手順 1、 2の画像 1 2012-2016 Honda CR-V Oil and Oil Filter Replacement, Oil and Oil Filter: 手順 1、 2の画像 2
    • Open the hood by pulling the hood latch.
    • Oil may be hot if the engine has not cooled.
    • Keep vehicle in park and off unless otherwise noted.
    • Chock both back wheels with blocks of wood to prevent car from rolling.
  2. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 手順 2、 2の画像 1 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 手順 2、 2の画像 2
    • Let the vehicle cool for 15 minutes if needed. Clean the area around the oil cap. Remove the oil cap.
  3. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 手順 3、 3の画像 1 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 手順 3、 3の画像 2 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 手順 3、 3の画像 3
    • Locate the dipstick and check oil level.
  4. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 手順 4、 1の画像 1
    • Place the drain pain under the chassis and align with the drain bolt.
  5. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 手順 5、 1の画像 1
    • Locate the drain bolt.
  6. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 手順 6、 3の画像 1 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 手順 6、 3の画像 2 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 手順 6、 3の画像 3
    • Remove the drain bolt with a 17mm socket wrench, and completely drain the oil.
  7. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 手順 7、 1の画像 1
    • Remove the oil filter with a 45mm oil filter socket.
  8. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 手順 8、 3の画像 1 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 手順 8、 3の画像 2 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 手順 8、 3の画像 3
    • Replace the drain bolt with a new drain bolt gasket (crush washer); Honda Washer, Drain Plug (14MM) 94109-14000. Use the 17mm socket wrench to tighten.
  9. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 手順 9、 2の画像 1 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 手順 9、 2の画像 2
    • Install the new filter in place of the old filter. Hand tighten instead of using the oil filter wrench.
  10. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 手順 10、 2の画像 1 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 手順 10、 2の画像 2
    • Place the medium funnel and add new 0W-20 full synthetic engine oil. Add 4.2 quarts of oil.
  11. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 手順 11、 1の画像 1
    • Replace the oil cap.
  12. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 手順 12、 1の画像 1
    • Start the vehicle, and check for any leaks around the oil filter and oil drain plug.
    • Stop the vehicle and let the engine rest for 5 minutes.
  13. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 手順 13、 3の画像 1 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 手順 13、 3の画像 2 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 手順 13、 3の画像 3
    • Use the dip stick to double check oil level and add more if needed.
    • Make sure the oil level is in between the low and high marks on the dip stick. Replace the dip stick and close the hood.
    • Reset the oil life in the maintenance section of the vehicle computer.
終わりに
6 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Clay Casey
メンバー登録日: 06/12/20
325 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team S1-G2, Lane Summer 2020 University of Memphis, Team S1-G2, Lane Summer 2020人のメンバー
UM-LANE-SU20S1G2
4 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 21
過去 7 日: 151
過去 30 日: 720
今までの合計 20,728
