メインコンテンツにスキップ
2012-2018 Nissan Versa Note Headlight Bulb Replacement
必要な工具と部品
  1. 2012-2018 Nissan Versa Note Headlight Bulb Replacement, Headlight Bulb: 手順 1、 2の画像 1 2012-2018 Nissan Versa Note Headlight Bulb Replacement, Headlight Bulb: 手順 1、 2の画像 2
    • Pull the hood lever.
  2. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 手順 2、 1の画像 1
    • Push the lever underneath the hood to the left.
    • The lever is located in the center underneath the hood.
  3. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 手順 3、 1の画像 1
    • Pull up the hood.
  4. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 手順 4、 1の画像 1
    • Insert the support rod into the slot.
    • The stent is located to the right of the hood.
    • The slot is located in the underside of the hood to the right.
  5. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 手順 5、 2の画像 1 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 手順 5、 2の画像 2
    • Pull out the connector from the bulb.
    • Depending on the make of your vehicle, you may have push the tab on the connector that reads "push" before pulling out the connector.
  6. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 手順 6、 1の画像 1
    • Twist the plastic ring out from the bulb.
  7. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 手順 7、 2の画像 1 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 手順 7、 2の画像 2
    • Pull out the old bulb.
    • High pressure halogen gas is sealed inside the halogen bulb. The bulb may break if the glass envelope is scratched or the bulb is dropped.
    • When handling the bulb, do not touch the glass envelope.
  8. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 手順 8、 2の画像 1 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 手順 8、 2の画像 2
    • Insert the replacement bulb.
  9. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 手順 9、 1の画像 1
    • Twist the plastic ring back onto the bulb.
  10. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 手順 10、 2の画像 1 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 手順 10、 2の画像 2
    • Insert the connector into the bulb.
ゴール
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Chelsea Chineme
メンバー登録日: 09/28/21
229 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 2-8, Raign Fall 2021 University of North Texas, Team 2-8, Raign Fall 2021人のメンバー
UNT-RAIGN-F21S2G8
2 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 45
過去 30 日: 214
今までの合計 12,803
