メインコンテンツにスキップ
2011 Mitsubishi Outlander Bumper Taillight Replacement
必要な工具と部品
  1. 2011 Mitsubishi Outlander Bumper Taillight Replacement, Bumper Taillight Bulb: 手順 1、 2の画像 1 2011 Mitsubishi Outlander Bumper Taillight Replacement, Bumper Taillight Bulb: 手順 1、 2の画像 2
    • Remember to turn the vehicle off and remove the key from the ignition.
    • Open the lower car trunk door.
    • The repair will be done in this car trunk section.
  2. 2011 Mitsubishi Outlander Bumper Taillight Replacement: 手順 2、 2の画像 1 2011 Mitsubishi Outlander Bumper Taillight Replacement: 手順 2、 2の画像 2
    • Remove the four plastic clips.
    • To remove the plastic clips place the flat screwdriver on the plastic head.
    • Do it slowly to avoid damage to the plastic clips.
  3. 2011 Mitsubishi Outlander Bumper Taillight Replacement: 手順 3、 2の画像 1 2011 Mitsubishi Outlander Bumper Taillight Replacement: 手順 3、 2の画像 2
    • Pull back the plastic cover.
  4. 2011 Mitsubishi Outlander Bumper Taillight Replacement: 手順 4、 3の画像 1 2011 Mitsubishi Outlander Bumper Taillight Replacement: 手順 4、 3の画像 2 2011 Mitsubishi Outlander Bumper Taillight Replacement: 手順 4、 3の画像 3
    • Insert the screwdriver and remove the small nut inside that hole.
    • This action can take a moment because there is no visibility of the screw. The action must be done by the user touch.
  5. 2011 Mitsubishi Outlander Bumper Taillight Replacement: 手順 5、 2の画像 1 2011 Mitsubishi Outlander Bumper Taillight Replacement: 手順 5、 2の画像 2
    • With the flat screwdriver remove the taillight housing.
    • Insert the flat screwdriver and slowly pull back to avoid damage the car paint.
    • Unplug the taillight housing.
  6. 2011 Mitsubishi Outlander Bumper Taillight Replacement: 手順 6、 2の画像 1 2011 Mitsubishi Outlander Bumper Taillight Replacement: 手順 6、 2の画像 2
    • Turn the light housing connector counter clockwise and carefully pull it out of the casing.
終わりに
To reassemble your device, follow these instructions in reverse order. Placing back the screw from step 3 can take a while.
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Adrian Omar Olivera_Olivera
メンバー登録日: 09/22/21
160 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 21
今までの合計 282
