メインコンテンツにスキップ
2011 Ford Fiesta Headlight Replacement
必要な工具と部品
  1. 2011 Ford Fiesta Headlight Replacement, Indicator Bulb: 手順 1、 1の画像 1
    • Park the car where you have room to work.
    • Check that the hand brake is on and the engine is off.
    • Wait for the car to cool down before opening the hood. The hot air from the engine may damage the eyes and cause burns.
    • Ensure that the car has rested for at least 30 minutes.
  2. 2011 Ford Fiesta Headlight Replacement: 手順 2、 3の画像 1 2011 Ford Fiesta Headlight Replacement: 手順 2、 3の画像 2 2011 Ford Fiesta Headlight Replacement: 手順 2、 3の画像 3
    • Pull the hood release under the driver's dashboard towards you.
  3. 2011 Ford Fiesta Headlight Replacement: 手順 3、 3の画像 1 2011 Ford Fiesta Headlight Replacement: 手順 3、 3の画像 2 2011 Ford Fiesta Headlight Replacement: 手順 3、 3の画像 3
    • Make sure there is space to insert fingers. If not, repeat step 2.
    • Push the yellow hood release to the left to open the hood.
  4. 2011 Ford Fiesta Headlight Replacement: 手順 4、 2の画像 1 2011 Ford Fiesta Headlight Replacement: 手順 4、 2の画像 2
    • Lift the hood with one hand and place the strut upright in the correct position.
    • Place strut in the hole to the left of the hood.
  5. 2011 Ford Fiesta Headlight Replacement: 手順 5、 3の画像 1 2011 Ford Fiesta Headlight Replacement: 手順 5、 3の画像 2 2011 Ford Fiesta Headlight Replacement: 手順 5、 3の画像 3
    • Use a flathead screwdriver to loosen the lower retained screw.
    • Collect the screws and store them somewhere safe.
  6. 2011 Ford Fiesta Headlight Replacement: 手順 6、 2の画像 1 2011 Ford Fiesta Headlight Replacement: 手順 6、 2の画像 2
    • Remove the upper retained screw.
    • Store the screw in a safe place.
  7. 2011 Ford Fiesta Headlight Replacement: 手順 7、 3の画像 1 2011 Ford Fiesta Headlight Replacement: 手順 7、 3の画像 2 2011 Ford Fiesta Headlight Replacement: 手順 7、 3の画像 3
    • Carefully remove the headlight.
    • The headlight is attached to three electrical connectors.
    • Gently pull up and towards your body.
    • Set the headlight to the side.
  8. 2011 Ford Fiesta Headlight Replacement: 手順 8、 3の画像 1 2011 Ford Fiesta Headlight Replacement: 手順 8、 3の画像 2 2011 Ford Fiesta Headlight Replacement: 手順 8、 3の画像 3
    • Press both ends of the bulb container to remove the electrical connector from the bulb container.
  9. 2011 Ford Fiesta Headlight Replacement: 手順 9、 3の画像 1 2011 Ford Fiesta Headlight Replacement: 手順 9、 3の画像 2 2011 Ford Fiesta Headlight Replacement: 手順 9、 3の画像 3
    • Pull out the bulb from the headlight.
    • Press both ends of the electrical connector to separate from the bulb container.
  10. 2011 Ford Fiesta Headlight Replacement: 手順 10、 1の画像 1
    • Make sure you do not hold the glass surface with your bare hands. The bulb may malfunction from the sweat in your hands.
    • Hold the black part of the bulb.
    • The bulb might break, so be sure to wear gloves and protective glasses.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Phillip Kataswa
メンバー登録日: 07/01/21
208 ポイント
1ガイドが承認済み
チーム
York University, Team S2-G13, Melo-Thaiss Summer 2021 York University, Team S2-G13, Melo-Thaiss Summer 2021人のメンバー
YORK-MELO-THAISS-SU21S2G13
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 47
過去 30 日: 236
今までの合計 5,727
