はじめに
This guide will help you safely and correctly replace the alternator from a 2011 - 2017 Volkswagen Jetta.
必要な工具と部品
Use the 10 mm socket wrench to do this step.
Loosen the nut on the connector by turning it counter-clockwise.
Locate the 4 screws holding the alternator in place two on the top and two on the bottom.
Remove cap and electrical connector located on the right side of the alternator before removing the alternator.
Photo was taken after the alternator was removed to provide a better picture.
4 の人々がこのガイドを完成させました。
2 件のコメント
What engine is this guide for?
