メインコンテンツにスキップ
2010-2013 Volkswagen Golf Fuse Replacement
  1. 2010-2013 Volkswagen Golf Fuse Replacement, Fuse: 手順 1、 1の画像 1
    • Safety Precaution: Before fixing your blown fuse, you must take caution. Make sure your keys are out of the ignition and that your car has not been running for 20 minutes before you start working on it. Failure to do so can cause a short circuit in the car’s electrical system.
  2. 2010-2013 Volkswagen Golf Fuse Replacement: 手順 2、 2の画像 1 2010-2013 Volkswagen Golf Fuse Replacement: 手順 2、 2の画像 2
    • Locate Fuse Box: Open the driver's side door, and on the exposed side of the dashboard, locate the removable panel.
  3. 2010-2013 Volkswagen Golf Fuse Replacement: 手順 3、 3の画像 1 2010-2013 Volkswagen Golf Fuse Replacement: 手順 3、 3の画像 2 2010-2013 Volkswagen Golf Fuse Replacement: 手順 3、 3の画像 3
    • Open the fuse box panel: gently prying it open to access the interior fuse box.
  4. 2010-2013 Volkswagen Golf Fuse Replacement: 手順 4、 2の画像 1 2010-2013 Volkswagen Golf Fuse Replacement: 手順 4、 2の画像 2
    • Identify where the blown fuse is: The fuses are numbers; the fuse you are looking for is number 24.
  5. 2010-2013 Volkswagen Golf Fuse Replacement: 手順 5、 3の画像 1 2010-2013 Volkswagen Golf Fuse Replacement: 手順 5、 3の画像 2 2010-2013 Volkswagen Golf Fuse Replacement: 手順 5、 3の画像 3
    • Use a Fuse Puller: The puller is in the fuse box cover. You have to clamp the fuse with the fuse puller and pull the fuse out.
  6. 2010-2013 Volkswagen Golf Fuse Replacement: 手順 6、 3の画像 1 2010-2013 Volkswagen Golf Fuse Replacement: 手順 6、 3の画像 2 2010-2013 Volkswagen Golf Fuse Replacement: 手順 6、 3の画像 3
    • Install new fuse: Using the fuse puller, Place the new fuse into the empty slot in the box and ensure that the replacement fuse fits firmly.
  7. 2010-2013 Volkswagen Golf Fuse Replacement: 手順 7、 3の画像 1 2010-2013 Volkswagen Golf Fuse Replacement: 手順 7、 3の画像 2 2010-2013 Volkswagen Golf Fuse Replacement: 手順 7、 3の画像 3
    • Gently clip the cover back on the fuse: After you have replaced the fuse, make sure you put the fuse puller back on the back of the fuse box cover and cover the fuse box.
  8. 2010-2013 Volkswagen Golf Fuse Replacement: 手順 8、 3の画像 1 2010-2013 Volkswagen Golf Fuse Replacement: 手順 8、 3の画像 2 2010-2013 Volkswagen Golf Fuse Replacement: 手順 8、 3の画像 3
    • Test the Fuse: Turn on the ignition to start your car, make sure that the lights are working and that how you know you have successfully Fast Fix your problem.
終わりに
作成者
3人の作成者と共同で作成されました。
Mustafa alqasab
メンバー登録日: 09/19/23
157 ポイント
1ガイドが承認済み
チーム
York University, Team B-17, Woodhouse Fall 2023 York University, Team B-17, Woodhouse Fall 2023人のメンバー
YORK-WOODHOUSE-F23SBG17
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 89
過去 30 日: 370
今までの合計 1,106
