はじめに
I upgraded the factory Harman Kardon speakers to the Kicker KS60 2-way speakers in the rear doors of the vehicle — but you can use this guide to install any aftermarket speakers you'd like.
必要な工具と部品
Lift the hood of your Subaru so you can access the battery.
Use a 10 mm hex wrench to loosen the black Ground terminal screw.
Lift the terminal up and off the battery lead, taking care not to touch the Positive terminal.
Move the ground terminal out of the way so that it has no chance of accidentally reconnecting, or touching the Positive terminal.
Use a spudger or a flat-blade screwdriver to unlatch the plastic screw cover residing within the door pull handle.
Move the plastic cover out of the way so that the Phillips screw is fully revealed.
Use a #2 Phillips screwdriver to unscrew the screw residing underneath the plastic cover.
There are several retaining clips holding the door panel in place. Their locations are roughly outlined by the red circles.
You’ll find a notch in the door panel on the bottom of the door. This is where you should insert your door panel pry tool. You can also use a couple of flat-blade screwdrivers or a paint scraper in lieu of of a door panel pry tool, but you may accidentally damage your door panel’s paint.
Insert the door panel pry tool into the notch found on the bottom of the door panel.
Once fully inserted, pull towards you in order to disconnect the first retaining clip.
The door panel should now be slightly looser on the bottom. Re-insert the pry tool on the bottom-right of the panel, and pull toward you to disconnect the second retaining clip.
Two cables operate the door lock and door pull handle — a blue cable for the door lock, and a black one for the door pull handle. Each cable has a plastic sleeve that needs to be disconnected, as well as a metal cable ball that has to be de-routed from the door handle.
Firmly grip the plastic blue sleeve and disconnect it by pulling it perpendicularly away from the plastic bracket.
Lift the sleeve upwards so that the metal ball at the end of the cable is removed from its housing.
Pull the entire cable away from the door panel.
The speaker is connected on the back with speaker wire, so do not yank it out of its housing once you remove the screws.
Use a #2 Phillips screwdriver to unscrew the three Phillips retaining screws.
Gently pull the speaker an inch or two from the door in order to expose the wire and connector on the back of the speaker.
I also knew I would not ever return to the factory speakers, so this was a simple choice for me.
Use a pair of wire cutters to cut the factory speaker connector from the rest of the speaker wiring. Leave a bit of wire on the connector side, should you ever need to put it back onto the wires.
Trim the new speaker wire (that should've come with the speakers) to appropriate length. I usually leave about six inches of wire from the spade terminals so that they can be easily stripped.
Strip the new speaker wire ends in the same fashion as the door speaker wire.
Connect the other side of each butt connector to the new speaker wire:
Red to black-gray
White to gray
A low-cost alternative is either rubber or foam weather stripping tape.
Cut an approximately 1" wide strip of Dynamat and press it into both sides of the speaker opening.
Work your way around with more strips up until all of the speaker opening is covered in Dynamat or weather stripping tape.
Follow these instructions to reassemble your door properly!
4 の人々がこのガイドを完成させました。
