メインコンテンツにスキップ
2010-2014 Ford Mustang tire pressure maintenance
必要な工具と部品
    • Use a calibrated tire pressure gauge, typically one with a reset button, or a digital one, and measure the pressure of all four tires.
    • On the driver side door, there will be a sticker with the suggested tire pressure, mine was 35 psi, yours might be different.
    • Using a compressor add air to the tires as required. NOTE: all four tires should be at the same pressure. Also, final pressure measurements should be with the tires at ambient temperature.
    • Once you have determined the pressure in each tire is correct, replace the valve stem caps. When you get in the car and start it the alarm will still be on. Drive a few miles, and it should clear on its own.
    • This automatic clearing is NOT mentioned in the manual, and was not provided by the local Ford dealer. I found this by accident when I completed the above procedure.
    • If you have to replace a tire, and/or a Tire Pressure Sensor, there is a much more complicated procedure that is required. This procedure also requires the use of a TPS reset/Learning tool. The details for this procedure are available on the WEB.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Dave Bassett
メンバー登録日: 12/05/14
133 ポイント
1ガイドが承認済み
コメント 1 件
When you say valve stem caps. Do you mean the tire caps? Just replace them or take them off and put them back on?
Christopher DeNigris - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 41
今までの合計 7,586
