メインコンテンツにスキップ
2010-2014 Ford Mustang Fuses Replacement
必要な工具と部品
  1. 2010-2014 Ford Mustang Fuses Replacement, Blown Fuse Replacement: 手順 1、 2の画像 1 2010-2014 Ford Mustang Fuses Replacement, Blown Fuse Replacement: 手順 1、 2の画像 2
    • Turn off the vehicle before beginning the fuse changing process to avoid electrocution.
    • Pull the hood release lever near the drivers feet to release the hood.
    • Move to the front of the vehicle.
    • Push the latch below the center of the hood to the left to unlock and open the hood.
    • Lift the hood and support it with the hood strut.
  2. 2010-2014 Ford Mustang Fuses Replacement: 手順 2、 1の画像 1
    • The fuse box is located on the drivers side of the vehicle. It is a black rectangular box.
    • Open the fuse box by disengaging the latch on the left side of the fuse box by flipping it upwards or to the right.
  3. 2010-2014 Ford Mustang Fuses Replacement: 手順 3、 1の画像 1
    • Referencing the Fuse Box Diagram, identify the blown fuse that needs replacement.
  4. 2010-2014 Ford Mustang Fuses Replacement: 手順 4、 2の画像 1 2010-2014 Ford Mustang Fuses Replacement: 手順 4、 2の画像 2
    • Remove the fuse that correspondences to the electrical failure in the vehicle by carefully pulling the fuse straight up and out of the fuse box.
    • It is safe to do this with your hands, just move slowly and carefully as you remove the blown fuse.
    • Check for damage or discoloration in the fuse.
    • Replace the damaged fuse with the new fuse by pushing it back into the appropriate fuse port. The new fuse should sit flush with the other fuses and may click when inserted correctly.
    • Close the fuse box and fasten latch on left side of fuse box.
終わりに
To reassemble, follow these instructions in reverse order.
作成者
14人の作成者と共同で作成されました。
Christopher Pell
メンバー登録日: 09/26/12
251 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 15-45, Forte Fall 2012 Cal Poly, Team 15-45, Forte Fall 2012人のメンバー
CPSU-FORTE-F12S15G45
5 メンバー
6のガイドは作成済み
コメント 1 件
The fuse is stuck. How do I get it out.
Delia Gress - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 32
過去 30 日: 175
今までの合計 16,155
