メインコンテンツにスキップ
2010-2017 Suzuki Swift Rear Springs Replacement
必要な工具と部品
  1. 2010-2017 Suzuki Swift Rear Springs Replacement, jack up your car: 手順 1、 3の画像 1 2010-2017 Suzuki Swift Rear Springs Replacement, jack up your car: 手順 1、 3の画像 2 2010-2017 Suzuki Swift Rear Springs Replacement, jack up your car: 手順 1、 3の画像 3
    • CAUTION: THIS PROCESS IS POTENTIALLY DANGEROUS. Be aware of your surroundings and do not go underneath your vehicle until this step is completed.
    • Make sure the handbrake is on, and the gear is in reverse for manual or park for an automatic transmission car.
    • Follow the safety instructions of the jack stand and jack.
    • Refer to this guide for more detailed information on how to jack up a car.
    • Put the jack under the rear frame hook and jack up the back of the car until the jack stands can be put under the jack supports.
    • Put jack stands under the rear jack supports. Slowly lower the weight of the car onto them by lowering the jack.
    • Put the jack under the front sub frame and jack up the front of the car until the jack stands can be put under the jack supports.
    • Put jack stands under the front jack supports. Slowly lower the weight of the car onto them by lowering the jack.
  2. 2010-2017 Suzuki Swift Rear Springs Replacement, remove the tire: 手順 2、 1の画像 1
    • Using the 17mm socket, unbolt the wheel nuts and remove the tire from the hub.
  3. 2010-2017 Suzuki Swift Rear Springs Replacement, detach shock absorber: 手順 3、 3の画像 1 2010-2017 Suzuki Swift Rear Springs Replacement, detach shock absorber: 手順 3、 3の画像 2 2010-2017 Suzuki Swift Rear Springs Replacement, detach shock absorber: 手順 3、 3の画像 3
    • Put the jack under the wheel arm and let the jack bear the weight of the arm but not lift the arm.
    • Using the 17mm socket, unscrew the nut attaching the bottom of the shock absorber to the wheel arm.
    • Push the shock absorber towards the car to slide the bottom from the bolt.
    • Drop the jack holding the wheel arm to unload the spring.
  4. 2010-2017 Suzuki Swift Rear Springs Replacement, replace the spring: 手順 4、 3の画像 1 2010-2017 Suzuki Swift Rear Springs Replacement, replace the spring: 手順 4、 3の画像 2 2010-2017 Suzuki Swift Rear Springs Replacement, replace the spring: 手順 4、 3の画像 3
    • Using the crowbar, lift the bottom of the spring out while pushing down on the wheel hub.
    • Add the new spring from below. Push down on the wheel hub to ensure clearance at the bottom of the spring.
    • Ensure the bottom end of the spring aligns with the bulge on the rubber.
  5. 2010-2017 Suzuki Swift Rear Springs Replacement, attach shock absorber: 手順 5、 2の画像 1 2010-2017 Suzuki Swift Rear Springs Replacement, attach shock absorber: 手順 5、 2の画像 2
    • With the jack, push up the wheel arm until the shock absorber aligns with the wheel arm bolt.
    • Slide the shock absorber back on.
    • Apply threadlocker, put the washer and the nut back on and tighten to 90 N·m.
  6. 2010-2017 Suzuki Swift Rear Springs Replacement, attach tire: 手順 6、 1の画像 1
    • Place the tire flat against the wheel hub and make sure the hub holes line up with the rim holes.
    • With the 17mm socket, screw the wheelnuts back in. Tighten to 85 N·m.
終わりに
To replace the other rear spring, repeat the process on the other side of the car. When you’re finished, lower the car with the jack.
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
knipwim
メンバー登録日: 09/01/18
8,311 ポイント
30のガイドは作成済み
コメント 1 件
شكرا 🌹على اهتمامكم
amarsuzuki07 - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 34
今までの合計 639
