メインコンテンツにスキップ
2010-2017 Suzuki Swift Oil and Oil Filter Replacement
必要な工具と部品
  1. 2010-2017 Suzuki Swift Oil and Oil Filter Replacement, jack up your car: 手順 1、 3の画像 1 2010-2017 Suzuki Swift Oil and Oil Filter Replacement, jack up your car: 手順 1、 3の画像 2 2010-2017 Suzuki Swift Oil and Oil Filter Replacement, jack up your car: 手順 1、 3の画像 3
    • CAUTION: THIS PROCESS IS POTENTIALLY DANGEROUS. Be aware of your surroundings and do not go underneath your vehicle until this step is completed.
    • Make sure the handbrake is on, and the gear is in reverse for manual or park for an automatic transmission car.
    • Follow the safety instructions of the jack stand and jack.
    • Refer to this guide for more detailed information on how to jack up a car.
    • Put the jack under the rear frame hook and jack up the back of the car until the jack stands can be put under the jack supports.
    • Put jack stands under the rear jack supports. Slowly lower the weight of the car onto them by lowering the jack.
    • Put the jack under the front sub frame and jack up the front of the car until the jack stands can be put under the jack supports.
    • Put jack stands under the front jack supports. Slowly lower the weight of the car onto them by lowering the jack.
  2. 2010-2017 Suzuki Swift Oil and Oil Filter Replacement, Preparations: 手順 2、 1の画像 1
    • The oil pan is located at the bottom of your engine.
    • The oil drain plug is located at the back of the oil pan.
    • The oil filter is located at the front.
    • After engine use, wait until the drain plug can be touched with your bare hands, before attempting the change the oil.
  3. 2010-2017 Suzuki Swift Oil and Oil Filter Replacement, drain the engine oil: 手順 3、 2の画像 1 2010-2017 Suzuki Swift Oil and Oil Filter Replacement, drain the engine oil: 手順 3、 2の画像 2
    • Locate the oil filler cap and rotate left to remove it. This allows air into the top of the system while the oil drains away at the bottom.
    • Place the oil drain pan under the plug.
    • Unbolt the plug with a 14mm wrench and let the oil drain completely.
    • When drained, clean the drain plug and gasket and bolt it back on. Using torque wrench tighten it to:
    • 35 N·m for gasoline engines
    • 20 N·m for diesel engines
  4. 2010-2017 Suzuki Swift Oil and Oil Filter Replacement, replace the oil filter: 手順 4、 3の画像 1 2010-2017 Suzuki Swift Oil and Oil Filter Replacement, replace the oil filter: 手順 4、 3の画像 2 2010-2017 Suzuki Swift Oil and Oil Filter Replacement, replace the oil filter: 手順 4、 3の画像 3
    • Attach a filter wrench to the filter and turn counter clockwise. Repeat until the filter can be unscrewed by hand.
    • Place the oil drain pan under the filter, unscrew the oil filter and let the remaining oil drain.
    • Clean the connecting surface.
    • Lubricate the rubber gasket on the new oil filter with some engine oil.
    • Screw the new filter on (hand tight).
    • Using the filter wrench, add 3/4 turn to tighten it.
  5. 2010-2017 Suzuki Swift Oil and Oil Filter Replacement, add the new engine oil: 手順 5、 3の画像 1 2010-2017 Suzuki Swift Oil and Oil Filter Replacement, add the new engine oil: 手順 5、 3の画像 2 2010-2017 Suzuki Swift Oil and Oil Filter Replacement, add the new engine oil: 手順 5、 3の画像 3
    • Ensure the car is level to ensure a correct dipstick measurement.
    • Using the funnel, add the required amount of oil for your engine type. You can add less for comfort, measure, and add more incrementally.
    • To measure, perform the following actions:
    • Pull the dipstick from the engine and wipe it clean.
    • Insert the clean dipstick completely and pull it out again.
    • The oil level should be between the 2 markers.
    • To allow the oil to distribute through the system, idle the engine a couple of minutes. Check the oil level again and check for leaks.
    • When finished, put back the oil filler cap and turn right to close. Clean any spilled oil from the engine.
  6. 2010-2017 Suzuki Swift Oil and Oil Filter Replacement, reset the oil check light: 手順 6、 3の画像 1 2010-2017 Suzuki Swift Oil and Oil Filter Replacement, reset the oil check light: 手順 6、 3の画像 2 2010-2017 Suzuki Swift Oil and Oil Filter Replacement, reset the oil check light: 手順 6、 3の画像 3
    • Resetting the oil check light is done inside the setting mode.
    • Enter the setting mode by switching the car key to the ON position and selecting "range" with the display selector, and pressing the display selector for at least 2 seconds.
    • The menu has 4 options which can be scrolled through by turning the display selector left or right.
    • Scroll until you see the oCl (oil clear) option. Press the display selector to enter the menu option and select the reset action.
    • Confirm the reset action by pressing the display selector. You will see a succe message and will return in the menu.
    • Scroll the menu until you see the end option and press the display selector to confirm.
終わりに
Lower your car now if you haven’t done so when leveling the car for taking an oil measurement.
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
knipwim
メンバー登録日: 09/01/18
8,565 ポイント
31のガイドは作成済み
2 件のコメント
<a href="https://www.dewaninternational.com/">5w30 engine oil</a>
<a href="https://www.dewaninternational.com/">10w30 engine oil</a>
<a href="https://www.dewaninternational.com/">10w40 engine oil</a>
nadeem khan - 返信
Good job. what are those two caps under the oil pan? what are they for? Thank you.
Gio _ - 返信
コメントを追加
統計データ:
過去 24時間: 20
過去 7 日: 208
過去 30 日: 938
今までの合計 29,429
