はじめに
A non functioning dome light can be the result of a burned out light bulb. This guide will show you how to replace it.
必要な工具と部品
Grab the light fixture at the switch side and pull it loose.
Pull the power connector out by pushing on the retaining clip and pushing from below simultaneously.
Grab the bulb and push it out of the fitting.
Insert the new bulb by slotting it in on the flexible end and pushing it in. Make sure the other end is slotted into the fitting.
If you are using a LED light, make sure you turn the lights towards the lens after installation.
終わりに
