はじめに
The door handle of a vehicle is prone to degrade overtime. This guide will help you with the car door replacement of a 2009 Kia Sorento. The tools used were a flat head screwdriver and socket wrench with a 10mm attachment.
必要な工具と部品
Before you can start removing the side panel, the speaker on the driver side door must be removed. To do this, simply squeeze and it will pop out. There is a little wire that connects the speaker to the car. To detach it there is a little button that can be pushed and it will come loose.
5 の人々がこのガイドを完成させました。
