メインコンテンツにスキップ
2009-2012 Toyota Corolla Cabin Air Filter Replacement
必要な工具と部品
  1. 2009-2012 Toyota Corolla Cabin Air Filter Replacement, Cabin Air Filter: 手順 1、 2の画像 1 2009-2012 Toyota Corolla Cabin Air Filter Replacement, Cabin Air Filter: 手順 1、 2の画像 2
    • Get into the front passenger seat and open the lower glovebox.
  2. 2009-2012 Toyota Corolla Cabin Air Filter Replacement: 手順 2、 2の画像 1 2009-2012 Toyota Corolla Cabin Air Filter Replacement: 手順 2、 2の画像 2
    • Push the two side walls of the glovebox towards the center to free the stopper peg on each side.
  3. 2009-2012 Toyota Corolla Cabin Air Filter Replacement: 手順 3、 1の画像 1
    • Move to the right side of the glovebox and gently pop off the black retaining arm.
  4. 2009-2012 Toyota Corolla Cabin Air Filter Replacement: 手順 4、 1の画像 1
    • Gently lower the glovebox to the floor. It should hang in the position shown.
    What about the storage box above the glove box that blocks access to the filter? Is there enough room as shown to swing open the filter door access without removing the your box as well?
    John Shoaf - 返信
  5. 2009-2012 Toyota Corolla Cabin Air Filter Replacement: 手順 5、 3の画像 1 2009-2012 Toyota Corolla Cabin Air Filter Replacement: 手順 5、 3の画像 2 2009-2012 Toyota Corolla Cabin Air Filter Replacement: 手順 5、 3の画像 3
    • Release the tab on the right side of the air filter cover, and swing it to the left. It should then easily pull away.
  6. 2009-2012 Toyota Corolla Cabin Air Filter Replacement: 手順 6、 1の画像 1
    • Pull the old cabin air filter out of the housing.
    • Cabin air flows top to bottom (your old filter should be dirty on the top to illustrate this). Some filters will have an arrow stating to point arrow up, while others will have the arrow go in the direction of the airflow, which would be down. Install new filter accordingly.
ゴール
30 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Geoff Wacker
メンバー登録日: 09/30/13
89,935 ポイント
89のガイドは作成済み
8 件のコメント
This is great! Thank you so much :) Saved $80
Erik Phillips - 返信
The direction of airflow is definitely from top to bottom. I stuck a piece of paper in while the cabin filter was out with fan running, it pulled the paper downward. Be careful not to let the paper go too low because it will hit the fan just a couple inches below the filter compartment.
tom.mcgathen - 返信
There is another air filter above this one. Anyone know how to remove it so it can be cleaned or replaced?
Wayne - 返信
I’m an 85 year old widow and I can follow these detailed instructions. Thank you very much.
Frances Pearce - 返信
Very useful . Very well explained with detailed pictures
M M Mozumder - 返信
Very helpful. But for Right hand drive cars the filter cover un-clips from the left hand edge.
nzpilgrim - 返信
Your instructions are the best! The new filter can have an "up" arrow or an "airflow" arrow. You are the only one that explained the air flow properly! Thanks!
michael kedrowski - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 87
過去 30 日: 350
今までの合計 59,805
