メインコンテンツにスキップ
はじめに
Over time, your cabin air filter will become clogged with dust, leaves, hair, and other debris, leading to reduced cabin air flow. Toyota recommends replacing the cabin air filter every 10,000 miles, and charges a premium to do it. Follow this guide to replace your cabin air filter and save yourself money and time. Replacement will take about 5 minutes, and requires no tools. I used the STP CAF1816P cabin air filter found at a local auto parts store, but the Corolla will accept a variety of aftermarket cabin air filters, including the TYC 800025P and the FRAM CF10285.
ツール
ツールは指定されていません。
  1. 2009-2012 Toyota Corolla Cabin Air Filter Replacement, Cabin Air Filter: 手順 1、 2の画像 1 2009-2012 Toyota Corolla Cabin Air Filter Replacement, Cabin Air Filter: 手順 1、 2の画像 2
    • Get into the front passenger seat and open the lower glovebox.
  2. 2009-2012 Toyota Corolla Cabin Air Filter Replacement: 手順 2、 2の画像 1 2009-2012 Toyota Corolla Cabin Air Filter Replacement: 手順 2、 2の画像 2
    • Push the two side walls of the glovebox towards the center to free the stopper peg on each side.
  3. 2009-2012 Toyota Corolla Cabin Air Filter Replacement: 手順 3、 1の画像 1
    • Move to the right side of the glovebox and gently pop off the black retaining arm.
  4. 2009-2012 Toyota Corolla Cabin Air Filter Replacement: 手順 4、 1の画像 1
    • Gently lower the glovebox to the floor. It should hang in the position shown.
  5. 2009-2012 Toyota Corolla Cabin Air Filter Replacement: 手順 5、 3の画像 1 2009-2012 Toyota Corolla Cabin Air Filter Replacement: 手順 5、 3の画像 2 2009-2012 Toyota Corolla Cabin Air Filter Replacement: 手順 5、 3の画像 3
    • Release the tab on the right side of the air filter cover, and swing it to the left. It should then easily pull away.
  6. 2009-2012 Toyota Corolla Cabin Air Filter Replacement: 手順 6、 1の画像 1
    • Pull the old cabin air filter out of the housing.
    • Cabin air flows top to bottom (your old filter should be dirty on the top to illustrate this). Some filters will have an arrow stating to point arrow up, while others will have the arrow go in the direction of the airflow, which would be down. Install new filter accordingly.
ゴール
26 の人々がこのガイドを完成させました。
Geoff Wacker
メンバー登録日: 2013年09月30日
86,688 ポイント
89のガイドは作成済み
6 件のコメント
This is great! Thank you so much :) Saved $80
Erik Phillips - 返信
The direction of airflow is definitely from top to bottom. I stuck a piece of paper in while the cabin filter was out with fan running, it pulled the paper downward. Be careful not to let the paper go too low because it will hit the fan just a couple inches below the filter compartment.
tom.mcgathen - 返信
There is another air filter above this one. Anyone know how to remove it so it can be cleaned or replaced?
Wayne - 返信
I’m an 85 year old widow and I can follow these detailed instructions. Thank you very much.
Frances Pearce - 返信
コメントを追加
統計データを表示:
過去 24時間: 9
過去 7 日: 99
過去 30 日: 446
今までの合計 50,332
