メインコンテンツにスキップ
2008 Toyota Tundra Oil Change
必要な工具と部品
  1. 2008 Toyota Tundra Oil Change, Removing the Skid Plate: 手順 1、 2の画像 1 2008 Toyota Tundra Oil Change, Removing the Skid Plate: 手順 1、 2の画像 2
    • Begin by locating the skid plate. The Skid plate is attached by 5 Hex screws and 3 plastic retainer nuts. First, remove the 3 plastic retainer nuts by pulling on them until they are released.
  2. 2008 Toyota Tundra Oil Change, Removing the Skid Plate Continued: 手順 2、 3の画像 1 2008 Toyota Tundra Oil Change, Removing the Skid Plate Continued: 手順 2、 3の画像 2 2008 Toyota Tundra Oil Change, Removing the Skid Plate Continued: 手順 2、 3の画像 3
    • Next, obtain a socket wrench and ¼ extended socket. Start removing the 5 Hex screws. Remove the screws in a star pattern. Caution before removing the last 2 Hex Screws, have someone or something holding the skid plate so it does not fall.
  3. 2008 Toyota Tundra Oil Change, Open System: 手順 3、 2の画像 1 2008 Toyota Tundra Oil Change, Open System: 手順 3、 2の画像 2
    • Open oil fill cap and pull out dipstick slightly to allow for an open system when draining. These are located under the hood
  4. 2008 Toyota Tundra Oil Change, Draining the Oil: 手順 4、 3の画像 1 2008 Toyota Tundra Oil Change, Draining the Oil: 手順 4、 3の画像 2 2008 Toyota Tundra Oil Change, Draining the Oil: 手順 4、 3の画像 3
    • Locating the drain plug on the oil pan. Place drain pan underneath the drain plug in order to catch the old oil.
    • Using a ratchet and 14 mm socket, turn the drain plug counter-clockwise until drain plug comes out and oil starts to drain. Caution, oil may be warm if car had been operated within 30 minutes
  5. 2008 Toyota Tundra Oil Change, Reattaching Oil Drain Plug: 手順 5、 3の画像 1 2008 Toyota Tundra Oil Change, Reattaching Oil Drain Plug: 手順 5、 3の画像 2 2008 Toyota Tundra Oil Change, Reattaching Oil Drain Plug: 手順 5、 3の画像 3
    • Remove any gasket material from the drain plug and replace the sealing gasket. Screw the oil drain plug back into oil pan . Tighten until snug, do not over tighten
  6. 2008 Toyota Tundra Oil Change, Removing Oil Filter Cap: 手順 6、 3の画像 1 2008 Toyota Tundra Oil Change, Removing Oil Filter Cap: 手順 6、 3の画像 2 2008 Toyota Tundra Oil Change, Removing Oil Filter Cap: 手順 6、 3の画像 3
    • Locate the oil filter and begin to remove the oil filter cap. To do so, first grasp the oil filter canister with an oil filter wrench.
    • Then insert a ⅜ socket and slowly turn counterclockwise to loosen only the oil filter cap. This will expose the oil filter drain bypass.
  7. 2008 Toyota Tundra Oil Change, Draining Oil Filter: 手順 7、 3の画像 1 2008 Toyota Tundra Oil Change, Draining Oil Filter: 手順 7、 3の画像 2 2008 Toyota Tundra Oil Change, Draining Oil Filter: 手順 7、 3の画像 3
    • Place drain pan underneath oil filter and firmly Insert oil filter cap drain tool. This comes with the filter when you buy it. Oil will begin to drain from inside the filter canister.
    • When draining has stopped, remove drain tool by firmly pulling down.
  8. 2008 Toyota Tundra Oil Change, Removing and Replacing Oil Filter: 手順 8、 3の画像 1 2008 Toyota Tundra Oil Change, Removing and Replacing Oil Filter: 手順 8、 3の画像 2 2008 Toyota Tundra Oil Change, Removing and Replacing Oil Filter: 手順 8、 3の画像 3
    • To remove oil filter canister, use an oil filter wrench. Unscrew by turning counter-clockwise.
    • Remove the old oil filter from oil filter canister and replace with the new one.
  9. 2008 Toyota Tundra Oil Change, Reattaching Oil Filter Canister: 手順 9、 3の画像 1 2008 Toyota Tundra Oil Change, Reattaching Oil Filter Canister: 手順 9、 3の画像 2 2008 Toyota Tundra Oil Change, Reattaching Oil Filter Canister: 手順 9、 3の画像 3
    • Re-install oil filter canister. Tighten oil filter canister to 20-30nm
    • Replace oil filter gasket to insure the oil filter will not leak. This comes with the new oil filter
    • Reinstall oil filter cap. Tighten until snug, do not over tighten
  10. 2008 Toyota Tundra Oil Change, Adding New Oil: 手順 10、 3の画像 1 2008 Toyota Tundra Oil Change, Adding New Oil: 手順 10、 3の画像 2 2008 Toyota Tundra Oil Change, Adding New Oil: 手順 10、 3の画像 3
    • Using a funnel, pour in the new oil into the engine. Consult owners manual to see proper oil to use as well as amount of oil to add
    • Reinstall oil fill cap once filling oil is complete
  11. 2008 Toyota Tundra Oil Change, Checking Oil Level: 手順 11、 3の画像 1 2008 Toyota Tundra Oil Change, Checking Oil Level: 手順 11、 3の画像 2 2008 Toyota Tundra Oil Change, Checking Oil Level: 手順 11、 3の画像 3
    • Pull the dipstick out in smooth upward motion, wiping off the dipstick, reinstall, and pull the dipstick out once more to check level. Oil should be between dots on the bottom of dipstick
    • Write down date of oil change and amount of miles on vehicle to indicate when you should change your oil again.
終わりに
Changing your cars oil is the most important maintenance process that should be done for your vehicle. It can easily be done at home rather than taking it to an expert and being charged extreme amounts.
作成者
3人の作成者と共同で作成されました。
Jehad Esmail
メンバー登録日: 04/24/21
194 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 141
今までの合計 5,908
