メインコンテンツにスキップ
はじめに
This guide will show you how to replace the battery in a 2008 Toyota Corolla. To get started, ensure the vehicle is parked in a safe place and turned off. Place the vehicle in park and engage the parking brake. Be sure to prepare baking soda mixed with water to clean the terminals.
パーツ
パーツは指定されていません。
  1. 2008 Toyota Corolla Battery Replacement, Battery: 手順 1、 2の画像 1 2008 Toyota Corolla Battery Replacement, Battery: 手順 1、 2の画像 2
    • Open the car hood.
    • The battery will be located on the bottom right.
  2. 2008 Toyota Corolla Battery Replacement: 手順 2、 2の画像 1 2008 Toyota Corolla Battery Replacement: 手順 2、 2の画像 2
    • There are two terminals on the battery. The positive terminal is on the left with the red cover. The negative terminal is on the right.
    • Unscrew the bolt to loosen the negative terminal.
    • Remove the negative terminal from the battery.
  3. 2008 Toyota Corolla Battery Replacement: 手順 3、 2の画像 1 2008 Toyota Corolla Battery Replacement: 手順 3、 2の画像 2
    • Take the red cover off the positive terminal.
    • Unscrew the bolt to remove the positive terminal.
    • Loosening the screws of the terminal can be difficult. In the first picture, I used pliers to help loosen up the screw holding the terminal tight.
  4. 2008 Toyota Corolla Battery Replacement: 手順 4、 3の画像 1 2008 Toyota Corolla Battery Replacement: 手順 4、 3の画像 2 2008 Toyota Corolla Battery Replacement: 手順 4、 3の画像 3
    • Disconnect the battery's terminals from the battery, and remove the old battery.
    • Batteries, over time, tend to get dirty. You can mix baking soda with water and use a brush to clean your terminals.
  5. 2008 Toyota Corolla Battery Replacement: 手順 5、 3の画像 1 2008 Toyota Corolla Battery Replacement: 手順 5、 3の画像 2 2008 Toyota Corolla Battery Replacement: 手順 5、 3の画像 3
    • Once everything is clean, you can begin installing your new battery.
    • Install your new battery in the correct space. You will install the negative terminal first, then the positive terminal.
    • Before moving on, make sure each screw on the terminal is tight and secured.
  6. 2008 Toyota Corolla Battery Replacement: 手順 6、 1の画像 1
    • Ensure that every bolt is secured.
    • Start your car and let your car run for a couple of minutes.
ゴール
Lair Noriega
メンバー登録日: 2022年04月04日
133 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 4-84, Briggs Spring 2022 CSU Los Angeles, Team 4-84, Briggs Spring 2022人のメンバー
CSULA-BRIGGS-S22S4G84
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 18
過去 30 日: 108
今までの合計 376
