はじめに
This guide is intended for the 2008 Suzuki SX4 Hatchback. It aims to replace the rear brake light bulb, in the case that it is broken or malfunctioning, with an original halogen or LED equivalent.
Having a broken brake light is dangerous for all drivers. In most countries, and in the United States, it is illegal to drive with a broken brake light. Doing so can not only get you into legal trouble, but also in dangerous situations. Driving without one can potentially cause an accident and can cost you your life. It is important to replace this light as soon as possible.
It is an easy fix that does not require you to seek service from a mechanic. Be careful, however, since this guide does involve handling light bulbs and glass. Light bulbs can be dangerous to handle if they have been recently used; you can receive burns or cuts from broken glass if you're not careful!
必要な工具と部品
With your vehicle in PARK, engage the emergency parking brake.
Turn off your vehicle and make sure all light switches are set to OFF.
To reassemble the housing, follow these instructions in reverse order. Once everything is reassembled, turn on all your vehicle lights and ensure all rear lights are functioning.
ある他の人がこのガイドを完成しました。
